It is currently Thu May 21, 2026 9:09 am
 Post subject: Spring hangers
PostPosted: Thu Sep 14, 2006 8:49 am
Are the spring hangers for a 71/4 rear the same as the ones on an 83/4 rear? I think the springs are the same dimensions, just wondering about the bushings, or any other differences.
"that's a nice car....are you gonna fix it up some day?"
PostPosted: Thu Sep 14, 2006 8:10 pm
Information on the hangers and shackles, anyone??
PostPosted: Thu Sep 14, 2006 9:21 pm
hanger and shackles are all the same... the only thing that changes between the 2 rear ends is the u bolts that hold the diff to the springs and the shock plates they bolt to.
"I don't like these seatbelts, they're too complicated." - my lovely girlfriend in reference to my 71 duster seatbelts
PostPosted: Fri Sep 15, 2006 2:48 pm
Thanks much, just what I wanted to know.
PostPosted: Fri Sep 15, 2006 3:37 pm
Don't forget you will have to shorten your driveshaft ~1.75" - This figure varies depending on who you ask. You can always install the rear, move car to flat surface, slip the yoke on your tranny pushing it in all the way, pull it out an inch or so then measure.
PostPosted: Fri Sep 15, 2006 3:47 pm
Thanks Pierre.
PostPosted: Fri Dec 29, 2006 11:08 pm
The eyebolt might be a different size. I've seen at least 3 different eyebolt sizes on A body cars. 1/2, 9/16 and 5/8. There might even be a 7/16 eyebolt size on the early cars but I'm not positive on that one.
 Post subject: correct
PostPosted: Sat Feb 03, 2007 5:58 am
Car Model: '63 Dart GT Convertible
andyf is correct. The hanger box did go from 3 bolts to 4 bolts at some time, but I don't know what year the change was made.
ifyoubegintothinkyou'relosingcontrol...it'salreadygone
