It is currently Mon May 18, 2026 11:19 pm
 Post subject: Doc - No Oil Cont'd
PostPosted: Mon Dec 10, 2001 8:04 am
Doc - Spoke with Hughes this am. Said they could drill the cam but would need a old one for a pattern. They don't have a /6 cam since they only sell 1 or 2 a year. I no longer have the old cam. If the drilling route is selected I assume the hole in the journal would have to be in perfect alignment with the bearing holes. Probably pretty hard material also.
usclstaffingnet@sprintmail.com
PostPosted: Mon Dec 10, 2001 11:44 am
: Doc - Spoke with Hughes this am. Said they
: could drill the cam but would need a old one
: for a pattern. They don't have a /6 cam
: since they only sell 1 or 2 a year. I no
: longer have the old cam. If the drilling
: route is selected I assume the hole in the
: journal would have to be in perfect
: alignment with the bearing holes. Probably
: pretty hard material also.
The cam material is not all that hard to drill. Getting the two hole positioned correctly is critical. I will draw up and post the info. tonight. Should I send Hughes a stock cam for them to reference?? (will you cover my shipping cost?)
