It is currently Wed May 20, 2026 5:30 pm
Post new topic  Reply to topic  [ 23 posts ]  Go to page Previous 1 2
 Post subject: Baxter's
PostPosted: Sun Sep 17, 2006 1:20 pm
I just bought a CV230 Saturday morning from Baxter's here in Salem, I guess I got the last one from their Portland Warehouse, you might try them as Carquest here seems to not wholly support our era of car all the time...
PostPosted: Mon Sep 18, 2006 7:12 am
I've been to Baxter's, they weren't any help at all. Just like everybody else. I have one coming I bought off of ebay, and I'm going to pick up a whole extra super six set up off of a 77 van. I guess I have realized through this how beneficial that collection of a million extra parts can be....
1973 Dart Swinger Super 6 with 71k
1976 Datsun 280ZX with Mopar I-6
PostPosted: Mon Sep 18, 2006 10:25 pm
Dan, I disagree with this. I have seen this posted, before, and couldn't visualize it, so didn't want to call anyone out about it. Tonight I removed a valve body from a trans, and took a close look. Tried to get the lever to miss the valve. The only way that can happen, is if the "E" clip on the kickdown lever shaft is removed. Then the shaft can drop, and the internal lever can miss the valve. Thing is, even if the "E" clip were missing, the shaft still couldn't drop, if the external kickdown lever was still on the shaft.
*Shrug* Seen it happen too many times for it to be "impossible". Perhaps some years didn't have the E-clip, maybe it was added to prevent this problem. Remember, most 2bbl conversions do involve removing the external kickdown lever! :shock:
PostPosted: Tue Sep 19, 2006 6:02 pm
I'm no expert like some on this site, so maybe I am wrong on this, but I just went through this with my conversion. I adjusted the rod all the way forward as far as it would go, but the rod still wasn't long enough (only by about 1/2 inch, I didn't get the trans lever with my kickdown package) to "kick down" when the engine was lugging on hills and shift at higher speeds. It also was shifting soft, almost slipping?. I just bent the rod slightly at each bend to give it the extra length. Now the trans kicks down when it should, and it shifts at much higher speeds, It acually works great.
BTW, before I did this, I dropped the trans pan and made sure the lever was pushing the button when the lever was pushed back.
PostPosted: Tue Sep 19, 2006 6:29 pm
There is an ongoing controversy about the slant six kickdown levers. The super isx lever is supposed to be longer than the 1-barrel lever. But The one barrel lever on my Duster ws the same length as the two barrel lever. Weird.
Sounds like you have the short lever RDJ. Bending the rod made up the difference in the lever length.
82 D150-225/727
02 Dakota-3.9/5 speed
 Post subject: Should've never...
PostPosted: Tue Sep 19, 2006 7:30 pm
Should've never shown you the shed..... :shock:
PostPosted: Tue Sep 19, 2006 9:17 pm
Shorter.
PostPosted: Wed Sep 20, 2006 12:23 pm
Shorter.
Dan, this may have come up before, but do you happen to have measurements for how much shorter?
Used to own:
'82 Dodge D150
Erson 270 Cam, O/S valves, mild port work, ~9.5:1 compression
Currently fighting with an '85 VW Cabriolet
My other passion
