It is currently Wed Jun 17, 2026 10:29 pm
 Post subject: Engine Tuning Advice
PostPosted: Wed Sep 20, 2006 9:20 am
Hello everyone,
I have a mildly modified slant and I am looking for some tuning advice. My car runs OK, but I think it can run much better. It seems to accelerate well on the highway, but seems sluggish from a standstill. My car turned better times at the drag strip when I had the Super Six setip installed.
My setup (car = 1965 Valiant 200, 170 C.I slant):
Mopar Performance camshaft (244 duration, 436 lift)
Clifford 4-BBL intake
Holley 4160 390 CFM carb (stock settings)
Clifford 2-piece shorty headers
2 1/4 exhaust all the way back
Stock cylinder head
Stock rear-end (2:76 I believe)
Should I change jetting/power valve/?? on carb?
Should I the adjust timing?
Any advice is greatly appreciated!
1965 Valiant 200
170 C.I
PostPosted: Wed Sep 20, 2006 10:15 am
I'd look at two "fronts": for that carb is too low geared or for that gearing is too much carburetion.
Juan Ignacio Caino
PostPosted: Wed Sep 20, 2006 10:28 am
What rear end ratio would suit my needs? 3:23? 3:55?
1965 Valiant 200
170 C.I
PostPosted: Wed Sep 20, 2006 11:34 am
With a stock head on a 170 and a basically stock cam you are way over carbureted. It simply can not handle all those CFM's. With that carb you would not want your seconaries to ever open.
PostPosted: Thu Sep 21, 2006 4:44 am
I agree that new gears would help me out from a standstill....thats pretty obvious. I have read that jetting the carb with #49 and #52 jets is the best general purpose setting with the setup that I have. The car does run pretty rich with the settings I currently have. Should some head work be done to increase air flow?
1965 Valiant 200
170 C.I
PostPosted: Thu Sep 21, 2006 5:52 am
No, you need to get a 2-barrel. You are seriously overcarbed for that mild of a buildup.
I think a Super six would work well for your application.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Thu Sep 21, 2006 6:16 am
Alright guys.......thanks for the advice.....I still have the 2-BBL setup luckily. I appreciate the help!
1965 Valiant 200
170 C.I
