It is currently Fri Nov 27, 2026 8:43 pm
 Post subject: Which carb is this?
PostPosted: Tue Sep 26, 2006 5:08 pm
I have seen this carb at a local pick-a-part and on eBay.
It looks similar to a Holley 1945, but there is a cover on the top corner. Can anyone ID it?
My 1945 is dieseling and running rough, and I want to replace it with something else. Any thoughts?
Thanks Bill
 Post subject: Re: Which carb is this?
PostPosted: Tue Sep 26, 2006 5:13 pm
My thoughts? Forget the 1945 and grab a Holley 1920.
Used to own:
'82 Dodge D150
Erson 270 Cam, O/S valves, mild port work, ~9.5:1 compression
Currently fighting with an '85 VW Cabriolet
My other passion
 Post subject: Yep...
PostPosted: Tue Sep 26, 2006 5:53 pm
That's a Holley 1945, circa 1977-1978-ish I think. If it's OEM and new, then it should be OK for a while... The Holley 1920 is a better design and simpler to work with, but if they've sat in a junkyard or on a shelf for a while they have a tendency to give up the ship also.
PostPosted: Tue Sep 26, 2006 9:05 pm
Thanks.
1975 Dodge B200 Van SWB, 3.7L /6
1960 Ford Ranchero - Boss 302. 4spd
PostPosted: Wed Oct 11, 2006 7:06 pm
Would I have any trouble swapping out my original 1945 carb with this newer one?
 Post subject: Nope...
PostPosted: Wed Oct 11, 2006 7:58 pm
Should be pretty easy, all your 'stock' connections (assuming that you still have your emissions equipment in place like charcoal cannister, etc...)...
It should all swap tit-for-tat (and you can leave the idle enrichment circuit plugged like you picture if you van's carb was not equipped for it).
