It is currently Mon Jun 15, 2026 4:47 am
 Post subject: POR-15 vs RUSTBULLET
PostPosted: Thu Sep 28, 2006 7:26 am
Im trying to decide which one to use. I thought I was all set on Por-15 then stumbled on RustBullets web site. If half the claims they make are correct then Rust Bullit is the way to go.
Does anyone have any experence with these products? How long have you used them? Whats YOUR take.
Thanks
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Thu Sep 28, 2006 10:06 am
I've not tried Rustbullet, but I have used POR-15 for a number of years; overall I've been very pleased with it.
My wife and I wrote an article about my 1st use of POR-15 above my head:
http://www.tidewatermoparclub.com/TECH/tech5.html
Since, I've found that the standard POR-15 (before the high temp version came out) did not hold up well on my exhaust system, other than the tips. Eventually I plan to pull the exhaust and sandblast it and use the new high temp POR15.
PostPosted: Thu Sep 28, 2006 2:05 pm
Some time ago (years) I remember someone on moparts.com forum did a comparison of the two. He had a boat and painted one under water part with por15 and another with eastwood version - eastwood one was barely blemished while port15 one had visible rust on it.
PostPosted: Thu Sep 28, 2006 5:54 pm
About 7 months ago I used POR15 on the trunk of my 64 Dart when I sold the car last month the rust visible through the POR in the trunk. I was shocked, the car had been in the garage the whole time. I was going to try something different on my Valiant.
1966 Signet
Turbo Slant Six
PostPosted: Sat Sep 30, 2006 7:38 am
Hey Guys
I think Ill give the Rust Bullet a try. Ill post updates every once in a while, to let you know how it preforms.
Thanks
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Sat Sep 30, 2006 6:38 pm
Car Model: 63 Dart 81 D150
I used por 15 on my wifes rusty shadow roof about 10-12 months ago. Followed the instructions EXACTLY! I covered it in self etching primer from a spray can, them spray can sealer primer. Still looks like the day I did it.
This car lives outside 24/7. I used some leftover por 15 on my dart and my d100 without using their prep products, as a test with no primers to cover it. Most all of it still looks fine, though some of it is fading where it gets direct sun. Even where I painted a part of my cast iron MC on the dart it still looks great (no prep at all) all around there is the typical rust, but none where the por 15 is.
I have no knowlege of the other product.
good luck
tophat
PostPosted: Sat Sep 30, 2006 9:01 pm
I would use POR-15. I used there exhaust manifold paint before and it is very tough stuff.
82 D150-225/727
02 Dakota-3.9/5 speed
