It is currently Sat May 30, 2026 9:24 pm
PostPosted: Tue Sep 26, 2006 9:21 pm
Someone mentioned a late model altanator that is a 6 grove pulley and is also a direct replacement from mounting to wiring. Or was I dreaming?
I need the 6 groves for my serpentine system. I upgraded not to long ago to a dual field altanator and voltage regulator. Can I still use the upgraded wiring and regulator? Does this altanator have 3 points of contact? Bat,Field1, field2.
What model car do I tell NAPA its off?
PostPosted: Fri Sep 29, 2006 5:02 pm
Don't know what you want serp for but why not just swap a pulley??? I don't remember any chryslers from the 80's using a 6 rib serp I remember them all being 4 rib.
PostPosted: Fri Sep 29, 2006 5:24 pm
Or was I dreaming?...........there is no bolt on ...or easy swap. Super 6 has done it. He had talent, facilities and autocad on his side.
A search would reveal his detailed pictures and descriptions of this fairly complicated mod.
A good start is spelling altanator the more conventional way....alternator. It makes searches more successful.
PostPosted: Fri Sep 29, 2006 8:46 pm
My system has plans to leave the alternator in stock location or at least very close. Super 6's system does not do this. It also doesn't have A/C. It looks like a nice system but its not for me.
I have my system very close to being complete. Crank pulley has been made along with the idler pulleys bracket. Water pump pulley was a direct fit other than drilling 4 bolt holes in it. The alternator is all thats left. I thought that someone had mounted a late model one in the slants stock location, and it wasn't super6. This is what I may have been dreaming about, not whether or not I have that talent for such an indever.
Does the Intrepid alternator have 3 conection points? Bat, field, field or is it internaly regulated?
PostPosted: Fri Sep 29, 2006 9:14 pm
It's harder to get interested in helping you when many of your questions have already been answered, some of them several times.
PostPosted: Fri Sep 29, 2006 10:35 pm
I use the late model intrepid (nippondenso) alternator. It is externally regulated and connects the same way as the later dual field alternator, 2 fields and one battery. Will work with the stock regulator - but you'll have to take a heavy wire direct to battery or modify stock wiring/amp gauge. No special connectors, the terminals are ordinary studs.
It will fit the stock passenger side location with minor modification to bracket - you will have to shave 1/16" give or take because the ears on the nippondenso alternator are a touch closer together then stock.
I'm fairly sure it was a 6 rib but I can't be 100% as I chucked the pulley for a v groove. kragen.com pictures show it as 6 rib - I have an intrepid in the driveway if you want me to look.
Good luck with the project - keep the plans so things can be reproduced. But yes, as others have noted a search will net you with several posts about the nippondenso alternator conversion at least a la v-groove belts.
PostPosted: Sat Sep 30, 2006 6:50 am
intrepids have 6 groove pulleys.
Juan Ignacio Caino
PostPosted: Sat Sep 30, 2006 8:58 pm
What water pump pulley did you use? A chyrsler mini-van with a v6 has the correct alternator to use.
PostPosted: Sun Oct 01, 2006 8:40 am
water pump pulley is part#F3DE-8A528-AD-M
It's out of a 11/96 Sable GS 3.0.
There are some composit pulleys out there for the same car. This one is a steel pulley.
Users browsing this forum: Amazon [Bot] and 1 guest
