It is currently Sat May 16, 2026 11:32 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 5 posts ]
PostPosted: Sat Dec 15, 2001 5:54 pm
Just found this great site, best automotive site I have come across. It has always been a dream of mine to build a german/autobahn type mopar with tall gears, MPFI, and turbo.
Just a few questions:
1. Is there any forged low compression rod/pistons available for the SL6?
2. Is it possible to use hydraulic or roller lifters?
kysard@suscom.com
PostPosted: Sat Dec 15, 2001 10:09 pm
I think you'll have to have custom made most of
what you reference. EFI is documented in the articles at this site.
Turbos don't usually need a radical camshaft, you
can have a custom steel roller camshaft made for $$$. The 80s slants have hydraulic lifters.
: Just found this great site, best automotive
: site I have come across. It has always been
: a dream of mine to build a german/autobahn
: type mopar with tall gears, MPFI, and turbo.
: Just a few questions: 1. Is there any forged
: low compression rod/pistons available for
: the SL6?
: 2. Is it possible to use hydraulic or roller
: lifters?
PostPosted: Sun Dec 16, 2001 2:24 pm
: I think you'll have to have custom made most of
: what you reference. EFI is documented in the
: articles at this site.
: Turbos don't usually need a radical camshaft,
: you
: can have a custom steel roller camshaft made
: for $$$. The 80s slants have hydraulic
: lifters.
Do the 80's truck SL6 motors have the steel crank?
kysard55@suscom.net
PostPosted: Sun Dec 16, 2001 11:20 pm
: Do the 80's truck SL6 motors have the steel
: crank?
No, the forged steel cranks stopped in 1976 but the earler engine will swap-in.
With time, effort and the right parts, a SL6 performs very well. (BMWs watch-out!)
PostPosted: Mon Dec 17, 2001 8:53 pm
being good friends with a master machinist would help a lot too.
: No, the forged steel cranks stopped in 1976 but
: the earler engine will swap-in.
: With time, effort and the right parts, a SL6
: performs very well. (BMWs watch-out!)
: DD
