It is currently Fri Nov 27, 2026 12:14 am
Post new topic  Reply to topic  [ 17 posts ]  Go to page Previous 1 2
PostPosted: Wed Oct 04, 2006 10:47 am
That all depends on your crank case breather. Stock application for my '82 ram was a breather that had an internal filter and a fitting that then went up to the air cleaner. There was no filtration on the air cleaner, however, just a tube that sucked unfiltered air from the "dirty" side of the filter. I don't see how that gives any advantage. C
The "advantage" is that under WOT the PCV valve stops sucking, and crankcase vapors can blow out the breather cap (the normal "inlet"). If the inlet goes into the air cleaner housing, then the oil and blowby vapors go down the carb instead of gunking up the inside of the engine compartment.
PostPosted: Wed Oct 04, 2006 12:18 pm
Brilliant observation. Thanks.
Used to own:
'82 Dodge D150
Erson 270 Cam, O/S valves, mild port work, ~9.5:1 compression
Currently fighting with an '85 VW Cabriolet
My other passion
Users browsing this forum: Bing [Bot] and 33 guests
