It is currently Tue Jun 16, 2026 9:15 am
PostPosted: Tue Oct 03, 2006 5:58 pm
Would I be correct to say that the factory V AC compressor will not fit a motor equipped with the Offy 2 single carb manifold? Might a rotary compressor as found on late F Bodies and M Bodies work instead?
PostPosted: Tue Oct 03, 2006 8:42 pm
I would say most likely not. Here are some pics that might help you.
[/img]
PostPosted: Wed Oct 04, 2006 5:47 am
Thanks for the pictures! I'd say even with the rotary compressor, AC not possible with the twin singles. Thanks again!
PostPosted: Wed Oct 04, 2006 11:04 am
Looks too tight with the factory brackets and compressor location. Maybe you could fabricate brackets that place the compressor lower, further to the driver's side?
PostPosted: Wed Oct 04, 2006 4:40 pm
Might be able to cobble up some brackets and fit a rotary compressor where the power steering pump would go if the car had PS
PostPosted: Thu Oct 05, 2006 6:07 pm
Be advised there are at least two different bracketry setups for the V-type compressor on the slant-6. The early-type brackets (I want to say up to '66, maybe a couple years later) mount the compressor closer to the engine block; the later brackets move it several inches farther over towards the driver's side. When I used late-type brackets in my '65, it put the left outboard compressor head bolt into the battery case. I could've solved this with a smaller/different battery, but never got around to it.
It also does seem to me that one or another type of round-body compressor could be mounted on a "block hugger" type bracket down under the manifolds, where the DC generator was mounted on '60-'62 cars so equipped.
PostPosted: Fri Oct 06, 2006 9:38 pm
newer, smaller compressors from modern cars? old style AC won't fit in mostnarrowa's engine bay (up to'67 I think)
Juan Ignacio Caino
PostPosted: Sat Oct 07, 2006 8:00 am
The old-style (V2) compressor was used in A-bodies with dealer or factory A/C starting in '62, actually...!
PostPosted: Sat Oct 07, 2006 8:58 pm
won't fit with DUAL 1 barrel setup on up to 67 (i think) engine bays
Juan Ignacio Caino
