It is currently Sat Jun 13, 2026 10:51 am
PostPosted: Fri Oct 06, 2006 11:30 am
Well....
Ouch
Big problem with the lighting in the instrument cluster. I've been having problems with the lights on my instrument cluster since the purchase of this car. Finally I've fixed all the broken black bulb holders and replaced all the lightbulbs. Started her up... All the lights worked! Dropped it off to get a new windshield/gasket and *poof* no more turn signal lights working in the cluster. I reached under the dash and removed the bulb holder to check the bulb. The bulb is good. The contacts to the circuit board are also good. All lighting on the outside of the car is in working order. Hazards, turn signals, markers, and headlights all working. Also, the turn signal relay is recently replaced and upgraded to a solid state relay.
Can't figure out the problem with the instrument cluster turn signal lights?
Any help or experience would be appreciated...
Thanks
-chris
PostPosted: Fri Oct 06, 2006 12:09 pm
have you checked the fuses and turn signal bulbs?
you might want to PM slant six dan.
PostPosted: Fri Oct 06, 2006 3:40 pm
Interesting. Try swapping a known good bulb with holder out of one of the cluster illumination holes and into one of the turn indicator holes.
 Post subject: nope?
PostPosted: Fri Oct 06, 2006 4:06 pm
Tried swapping out bulb and holder. Light bulbs are good. Tried them in other places on the car. All exterior lights and fuses are good.
Any more advice ? Strugging over here...
PostPosted: Fri Oct 06, 2006 5:04 pm
Well, get out your voltmeter and start diagnosing! Ground the - probe, and put the + probe in the socket for the relevant pin on the rear of the instrument cluster. If you see +12v pulsed in time with the turn signal flasher, then the problem is with the circuit board, the bulb holder(s), or the connection between the socket sleeves and the mating pins. If no pulsed +12v, then move upstream and check at the relevant connection where the main wiring harness connects to the turn signal switch, at the base of the steering column.
PostPosted: Fri Oct 06, 2006 8:47 pm
Sadly the late A-bodies are notorious for a couple of bad things...leaky old windshield gaskets that let some water in on the instrument panel, and lack of QA/QC on instrument clusters...
Depending on how things go, you might take the time to pull the whole cluster out so you can visually inspect the circuit board itself... all it takes is a little corrosion spot on the back to really mess up a few of the gauges or lights on the late boards... (I should know I have several of these in a bin for "spare parts" to make good ones for later projects, and quite a few of the have one problem or another....)
PostPosted: Fri Oct 06, 2006 9:32 pm
I'll be trying out the test light... However there is no corrosion. I just took the whole cluster out and cleaned all the connections and replaced all the bulbs/holders and no luck. I was just hoping there might be a quick fix I didn't know about. Well here it goes! Thanks
PostPosted: Sat Oct 07, 2006 7:21 am
Ive had really good luck on circuit boards by "painting the foil side" with Krylon Crystal clear. As long as the circuit board is cleaned of corrosion
this will leave a thin coat on the board for years and keep any corrosion from ever forming.
If you have any questions about this PM or ask.
Thanks
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Sat Oct 07, 2006 10:32 pm
Well let me correct myself...
I was trying to check the lights without pulling the cluster back out. After getting frustrated with the lights, I dropped the column and pulled it out. All of my black bulb retainers are broken. I had attempted to fix them with a dab of hot glue. My thinking being, the soft glue would hold the bulbs in without damaging anything or being permanent.
This fix didn't seem to work. The bulbs backed off the circuit board just a millimeter or so.
So my next question is...
Anyone know a good place to pick up new bulb retainers?
PostPosted: Sat Oct 07, 2006 10:58 pm
You can get the bulb holders at Napa. I've also seen them at other parts stores in the electrical section with other connecters and sockets.
