It is currently Sat Nov 28, 2026 2:06 am
 Post subject: S belt
PostPosted: Wed Oct 11, 2006 8:06 am
I remember reading some topics on placeing an Serp belt on these /6's. This is my intention on mine but i dont remember if there is a standard bracket for this mod. Anyone know if i can order one of if i have to have one special made?
PostPosted: Wed Oct 11, 2006 8:59 am
It's 100% custom.
PostPosted: Wed Oct 11, 2006 1:32 pm
As Joshie said, it is a 100% custom conversion. I did it to my slant, search for "serpentine" and you should find two or three other posts where I have relayed everything I did to complete the conversion.
The short version: I had to fabricate a bracket, machine a water pump pulley, machine an adapter for a junkyard crank pulley, and adapt other junkyard components (alternator, automatic tensioner, and pulleys).
-S/6
The "Silver Bullet"
87 Ram D150
PostPosted: Wed Oct 11, 2006 1:42 pm
I'll admit this is probably a dumb question, but what's the inherent advantage in using a spring loaded tensioner over a solid, adjustable tensioner? It seems to me a solid adjustable tensioner mated to the alternator, for example, would be both easier to fabricate and have a longer service life.
Used to own:
'82 Dodge D150
Erson 270 Cam, O/S valves, mild port work, ~9.5:1 compression
Currently fighting with an '85 VW Cabriolet
My other passion
PostPosted: Wed Oct 11, 2006 5:03 pm
I am currently working on a serp system that leaves the alt in the stock location. It will also be able to handle multiable setups. ie- power steering A/C or none or ethier one. Crank pulley is done, Alt adapter just needs its parts welded and it will be done, water pump pulley came off a Sable and just needs the 4 holes redrilled. More info will come with pics as soon as its done.
PostPosted: Thu Oct 12, 2006 8:06 am
The advantages as I see it:
1) Only one tool is needed to change the belt (3/8 breaker bar with a 9/16" socket)
2) Belt tension remains basically constant, even as the belt stretches over time.
3) That constant belt tension is in the proper range. When my friend and I were deciding on where to place the tensioner, we took into account the torque (in various positions) of the automatic tensioner, and using a belt tensioner tool, were able to position the tensioner so as to provide the proper amount of belt tension, without being too tight.
PostPosted: Thu Oct 12, 2006 1:12 pm
I am not set up to perform this type of fabrication. I sure hope my local machine shop doesn't rape me when i present my desires to them when they overhaul my /6.
If so does this seem feasible, i will be running a custom electric fan for the custom radiator. can i just remove the hard mounted fan and run the normal V belts until i can get everything together for a quick swap out to S belt? Not sure if this will have an adverse effect on the motor.
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 4 guests
