It is currently Sat Jun 20, 2026 8:47 am
PostPosted: Fri Oct 13, 2006 7:10 pm
I need to rebuild the engine in a 65 signet convertible I just snagged. First off I need to know for sure that the V8 is in fact a 273. Can someone here tell me where the number is on the engine block?
Also, any help and links to parts information would be helpful.
Where is a good source for an engine complete rebuild kit?
I also need a drivers side front fender. I'm also interested in finding metal to replace the rust holes around both rear quarters.
All information would be greatly appreciated.
Steve
"25 years in a chicken coop project"
'65 Signet Convertible, 273 V8 2 brl
PostPosted: Fri Oct 13, 2006 7:14 pm
Hi Widget,
you should look on the driver's side of the block to find the casting number. The last three numbers denote the displacement.
-James
PostPosted: Fri Oct 13, 2006 7:46 pm
Pop off a valve cover and look at the rocker arms. If they have adjuster nuts on them, 99.9% of the time it is a 273. Regular stamped-steel rockers with no adjusters is a 318-360-340.
82 D150-225/727
02 Dakota-3.9/5 speed
 Post subject: Thanks James and Jeb,
PostPosted: Fri Oct 13, 2006 8:09 pm
James, where on the drivers side of the block? There is a lot of grease. Sure, I plan on yanking out the engine, but I'd like to start finding parts while the weather here settles over the next week.
PostPosted: Fri Oct 13, 2006 8:36 pm
Engine ID can be found, usually, driver's side front of the block or on the drivers side of the block near the freeze out plugs.
Russ
PostPosted: Sat Oct 14, 2006 6:14 am
Russ
Sounds about right. The numbers will be cast in rather than stamped. I think it's cool you're building a 273. Those are sweet little engines.
-James
PostPosted: Sat Oct 14, 2006 5:48 pm
Russ
-James
They sure are. They have floating piston pins and will wind up in a hurry. Plus the mechanical lifters give it a slant-like sound
82 D150-225/727
