It is currently Mon May 18, 2026 7:09 am
PostPosted: Sun Oct 15, 2006 10:21 pm
Yikes! I bought a '64 Valiant Signet Hardtop a month ago and just today got a chance to drive it to see what it needs. I have two four door '64's and I was thinking of parting one out to feed the others, putting the best stuff in the hardtop.
Anyway, I fired it up and drove it around, checking off what worked and what didn't, and the transmission was slipping and shifting hard. When I brought it home, I checked the fluid level with the engine on and the trans in neutral and it is almost dry! Did I do some damage? Should I just add fluid and check for leaks?
PostPosted: Mon Oct 16, 2006 3:35 am
Car Model: 63 Dart 81 D150
maybe ... but doubtful
yes ... if the condition of the trans is unknown, changing the filter is a good idea. I dont recall if it is in the pan or in the cooler like in 64
good luck
tophat
PostPosted: Mon Oct 16, 2006 4:50 am
I believe the filter is in the pan. It's probably a good idea to drop the pan anyway and have a look inside. Change the fluid and filter then have it adjusted. Those old torqueflites are tough and very reliable, with any luck at all you should be good to go.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Mon Oct 16, 2006 5:03 am
Make sure you get the correct filter. The 64 filter should have two holes for the fluid to go into the valve body. Most parts stores wil give you a filter with only one hole. These are for the 66 and newer trans. The 64 trans has a rear pump, which was removed as of 1966.
PostPosted: Mon Oct 16, 2006 6:42 am
Thanks, I'll replace the filter and break out the shop manual to find out about adjustment . I'm just kicking myself for not checking the level before driving it. I topped off the oil and the brake fluid, but the AT fluid escaped my attention. I wonder how long the previous owner drove it around like that? Not long I hope.
PostPosted: Mon Oct 16, 2006 4:11 pm
If it was sitting for a while before you bought it, check the rear seal, also. It's lubricated by trans fluid when the car is in motion, and if it has not been driven in a while, the seal could be dried out and cause leaks.
