It is currently Sat Jun 20, 2026 7:36 pm
 Post subject: Windshield Wipers
PostPosted: Mon Oct 16, 2006 2:38 pm
So, the other morning I'm driving, and the window is fogged up, so I use my wipers. They work just fine, as always. Then, about 3 minutes later I do the same... again, 3 minutes later I go to turn them on, and they don't move. I've never had a problem with them before, and now they don't work at all. This is bad since it is starting to rain. This is in a '70 Dart Custom
Thoughts?
I checked the fuses (or at least the ones I know of) and they seem fine.
Thanks!
PostPosted: Mon Oct 16, 2006 6:35 pm
I would check the switch/contacts as I have ran into problems with these before. In my ford van, the wipers will go up sometimes but get stuck and not come back down. I move the switch a bit (it has various speed delay on the switch) and they go back down. Electrical gremlins are weird but at least solveable in most older cars.
Russ
 Post subject: wipers
PostPosted: Mon Oct 16, 2006 9:29 pm
I have a 72 dart, it has two ballast resistors. One is on the wiper motor. could be the problem.
Excuse me, does this smell like chloroform to you?
