It is currently Fri Jan 30, 2026 8:04 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 5 posts ]
PostPosted: Tue Dec 25, 2001 4:06 pm
Doug, I am currently using a 2.7:1 ratio first geared a-833 non - o/d unit with the stock 9" clutch and pres. plate. As soon as my local napa gets the right clutch in (they had orded me a 10 spline unit) I will be upgrading to an A-833 non - O/D with the 3.09:1 low gear, And H/D 10" truck/ taxi Clutch - 23 spline. What kind of acceleration difference can I expect from the 3.09:1 Gear?
Thanks, Greg Ondayko
http://www.geocities.com/gao5498/slant6
gocar@prousa.net
PostPosted: Wed Dec 26, 2001 10:00 am
: Doug, I am currently using a 2.7:1 ratio first
: geared a-833 non - o/d unit with the stock
: 9" clutch and pres. plate. As soon as
: my local napa gets the right clutch in (they
: had orded me a 10 spline unit) I will be
: upgrading to an A-833 non - O/D with the
: 3.09:1 low gear, And H/D 10" truck/
: taxi Clutch - 23 spline. What kind of
: acceleration difference can I expect from
: the 3.09:1 Gear?
: The 3.09 first gear is 14% "lower" then the 2.65 so you will notice the difference. What is your rear end ratio? Example: 2.94 x 3.09 = 9.08 start-off ratio, 2.94 x 2.65 = 7.79
PostPosted: Wed Dec 26, 2001 10:22 am
: DD
The rear end ratio Is 3.23 - I am also Running some tall GR 60-14's out back. I figured the 3.09 would get me started faster, and I could still get the 20+ mpg on the highway with the Hyperpak.
Greg Ondayko
gocar@prousa.net
PostPosted: Wed Dec 26, 2001 2:14 pm
Just read your post, I have run a Hyper Pak in one car or another for 30 plus years. I ran it in a '64 Barracuda with a 3.09 and a 3.55 rear and 14 inch L60 Super Stock tires. It got 21 miles to the gallon running up and down the interstate from Newport News to Richmond. I was using a small Carter from a 273 Formula S Barracuda. Good luck with your ride!
Stan
PostPosted: Sun Jan 06, 2002 10:01 am
I do not know how many of you remeber this, but about 10-15 yaers back, Jack Pohler wrote an artical in the Slant Six News called Tires and Gearing. It was in the 63 Valiant issue I think. Is there anyway some of the old articals like that one could be posted somewhere? Or are they and I missed them? I used to enjoy reading his stuff, but if you called him or visited his house, it took forever to leave, he liked to talk. :) Good guy.
Scott
scott.solomon@mcchord.af.mil
