It is currently Thu Jun 25, 2026 6:20 am
Post new topic  Reply to topic  [ 26 posts ]  Go to page Previous 1 2
PostPosted: Sun Oct 15, 2006 10:35 am
Doc thanks for the picture it really clears things up. The tube in the picture looks like brass fuel line for model airplanes. I have some of this and it is a lot stiffer than the copper oil gauge tube, it just kinks easier in tight radiuses. I will try making one with that. If I cant get a new/rebuilt six hole oil pump what is the rebuild kit part number?
PostPosted: Mon Oct 16, 2006 4:48 am
... The tube in the picture looks like brass fuel line for model airplanes...
Any small, stiff wall tube will work. the copper tubing can be used if you solder on a stiffing plate to reinforce it.
If I can't get a new/rebuilt six hole oil pump what is the rebuild kit's part number?
Melling K66A for the 5/8 thick impeller size.
PostPosted: Mon Oct 16, 2006 6:55 pm
Well I had the local parts store look up the oil pump. No six bolt pumps available. He tried Melling and Fed Mog, nothing, all five bolters. :x He did find the part number for the Melling rebuild kit but nothing in the warehouse. I have a couple of other alternatives, I will try CarQuest and Crapa tomorrow, and see what channels my machinist can come up with. If push comes to shove, can I buy a five hole'r and swap all of the guts to the six hole housing?
PostPosted: Tue Oct 17, 2006 11:08 am
Just watch out for impeller thickness differences, most 5 hole pumps use the 7/8 thick impeller.
PostPosted: Tue Oct 17, 2006 11:06 pm
Thanks Doug. I'll double chech.
PostPosted: Sat Jan 27, 2007 7:02 pm
If I am reading this thread correctly, one can not spray oil directly in to the oil pump gears without a 6 bolt pump. Is this correct? The pump I have is a 7/8 Melling pump.
PostPosted: Sat Jan 27, 2007 7:14 pm
Yes, 6 bolt pumps have 3 sealed pockets, the unused "third pocket" will be used to mount the spray tube and channel oil pressure to.
5 bolt pumps only have 2 sealed pockets so they will not support this mod.
PostPosted: Sun Jan 28, 2007 9:09 am
I understand that with out the 6 bolt pump the mod pictured can not be done, but is there some other place I can tap into the spray oil onto the gear?
PostPosted: Tue Jan 30, 2007 5:48 pm
On my block, there isn't even a pocket for the six hole pump to mount up with (there was some casting flash, which I ground off. Looking at it, I'd say you should be able to drill the hole and plumb it with an external oil line fed from a standard five bolt pump. Maybe the pictures will explain what I mean a little more clearly:
Before
After
Used to own:
'82 Dodge D150
Erson 270 Cam, O/S valves, mild port work, ~9.5:1 compression
Currently fighting with an '85 VW Cabriolet
My other passion
PostPosted: Sun Jul 18, 2021 4:28 am
Can we get the pictures reposted on this please? They seem to be unhosted now. Thank you.
PostPosted: Sun Jul 18, 2021 8:26 am
Nevermind. I got it figured out.
Users browsing this forum: Amazon [Bot] and 4 guests
