It is currently Tue May 19, 2026 12:57 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 6 posts ]
 Post subject: Cam Button
PostPosted: Thu Dec 27, 2001 5:02 pm
Hey everyone and Happy Holidays. If my memory serves me right,I think it was Charlie who talked about fabrication of a cam button onto a stock timing cover.I can't find that info now.Think you could run it past me again?I would like to do that to my cover while I'm waiting for my block in the machine shop.
Thanks,Drew
MoparBrat63@aol.com
 Post subject: Re: Cam Button *PIC*
PostPosted: Fri Dec 28, 2001 9:52 pm
: Hey everyone and Happy Holidays. If my memory
: serves me right,I think it was Charlie who
: talked about fabrication of a cam button
: onto a stock timing cover.I can't find that
: info now.Think you could run it past me
: again?I would like to do that to my cover
: while I'm waiting for my block in the
: machine shop.
This is a good up-grade and easy to do if you have access to a welder.
I have a special center punch which screws into the cam's tapped front hole and then I install the cover and push the cam forward to create a centered punch mark to drill by.
I drill a 1/4 inch hole and use it to screw down a 3/8 - 24 unf nut. I weld on the nut, you can add a large flat washer to the backside to halp stiffen the area. I run a tap through the welded assembly, then use rocker arm "ball screw" and lock nut as the cam stop. I also grind smooth the bolt head "face" of the cam's timing gear mounting bolt.
Once everything is installed, you can adjust the stop so there is .005 of clearance and lock it down. (do this before the oil pan goes on, so you can reach in and move the cam back and forth to feel the clearance)
Close-up View of the Cam Stop
PostPosted: Sat Dec 29, 2001 9:26 am
: This is a good up-grade and easy to do if you
: have access to a welder.
: I have a special center punch which screws into
: the cam's tapped front hole and then I
: install the cover and push the cam forward
: to create a centered punch mark to drill by.
: I drill a 1/4 inch hole and use it to screw
: down a 3/8 - 24 unf nut. I weld on the nut,
: you can add a large flat washer to the
: backside to halp stiffen the area. I run a
: tap through the welded assembly, then use
: rocker arm "ball screw" and lock
: nut as the cam stop. I also grind smooth the
: bolt head "face" of the cam's
: timing gear mounting bolt.
: Once everything is installed, you can adjust
: the stop so there is .005 of clearance and
: lock it down. (do this before the oil pan
: goes on, so you can reach in and move the
: cam back and forth to feel the clearance)
: DD
Thanks Doc, I've copied the info this time.Very helpful. I have to wait for my block.
Thanks again, Drew 63GT
MoparBrat63@aol.com
PostPosted: Sat Dec 29, 2001 1:15 pm
: machine shop.
: Thanks,Drew
I am new to this slant sickness so please explain to me what this cam button is for thanks
s65fury@aol.com
PostPosted: Sat Dec 29, 2001 2:58 pm
: I am new to this slant sickness so please
: explain to me what this cam button is for
: thanks
A cam button is a device installed onto a timing cover to keep the cam from "walking" forward and possibly putting unneeded load on timing chain. Doc Dodge and other racers maybe able to give you a better explanation then I can.
Drew
MoparBrat63@aol.com
PostPosted: Sat Dec 29, 2001 11:30 pm
: explain to me what this cam button is for.
If you get a lot of forward cam movement, it can throw-off the gear mesh between the oil pump gear and the cam gear.
This results in gear ware and failure. It is a good idea to check the gear's contact pattern and center it. Ensure that the cam won't move off that spot with the cam stop.
