It is currently Fri May 01, 2026 5:48 pm
PostPosted: Thu Oct 19, 2006 6:52 pm
The spark plug debate has been covered many times here, I am not tryiong to start another one of those,
I just want to know If any one rusn the 75-up peanut plug head with a high compression motor - say 9.5 or higher.
I was wondering what plug selecton is out there for this application. or what you folks run in this application.
I run a high Coompression head on the dart, but I have the old style head with the big plug tubes - Seemes to be plenty of selection there because of the big and small blocks out there.
PostPosted: Thu Oct 19, 2006 7:49 pm
I run one at 9.5:1, using whatever the NGK book reccomended as stock. I'm fairly certain I have a couple valves in the process of burning off, but I don't believe it had anything to do with the plugs. Wish I had some more definitive information for ya.
Used to own:
'82 Dodge D150
Erson 270 Cam, O/S valves, mild port work, ~9.5:1 compression
Currently fighting with an '85 VW Cabriolet
My other passion
 Post subject: I'm not that high...
PostPosted: Thu Oct 19, 2006 9:09 pm
I'm running only 9.2:1 but...
I used to run NGK's that were UR-5's I think as they were "stock" in the book...Hotter would be UR-4 like the small block chevy uses...
I noticed that an extended plug the TR-4 is available but not sure how that might help things.
I'm currently running a set of AC-Delco RTS-45's as they seem to burn just right for the timing and intake/carb selection I've made (with winter coming on I may go up to a RTS-44)
good luck buddy!
-D.idiot
 Post subject: Racing Plug
PostPosted: Fri Oct 20, 2006 3:58 am
Champion RV-12YC
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
PostPosted: Fri Oct 20, 2006 5:25 am
11-1 and I use Autolites between 24-26 depending on whether I'm spraying or not. :shock:
I also use NGKs spraying, but I don't really like them and am going to toss them in the trash. :oops:
PostPosted: Fri Oct 20, 2006 5:35 am
your using 11 to 1 on your juice motor? do you retard the timing once the juice kicks on?
PostPosted: Fri Oct 20, 2006 9:28 am
I am running 9.8 compressoin and using autolite platnum 26's I believe
PostPosted: Fri Oct 20, 2006 12:30 pm
Maybe my setup just runs hot due to the stock exhaust(which I am going to upgrade)
But I had to dial all the way down to autolite 23's Because I just could not find a plug that was cold enough for my combo.
as I said, the stock exhaust is holding a lot of heat in the motor, and there Might Be the problem. I just bought a MP 6:1 Header and will run 3" all the way back - Current exhaust is stock, except for a 2" flowmaster 40 Delta Force.
PostPosted: Fri Oct 20, 2006 3:13 pm
Greg,
What total timing are you running? It may be better to run less advance and keep normal heat range plugs. On your combo, I don't think I would run anything over 28 deg total (mech) advance.
PostPosted: Sat Oct 21, 2006 4:52 am
Greg- your car is reeeeally going to wake up with that header!
you may only want 2 1/2" on the tail pipe, if you are getting a tight fit around the axle and gas tank, 3" into the muffler is good but not totally necessary
PostPosted: Sat Oct 21, 2006 5:18 am
Greg, I am interested in seeing how much difference you get over the Clifford header. I ran an MP in my Duster and always liked it. I have a Clifford in the red car and have always thought it was lackluster at best. :shock:
PostPosted: Sun Oct 22, 2006 12:49 pm
Well, First this setup is going into My daily Driver, a 79 Volare Duster, Not the dart Pictured in the sig. Line, so it will be hard to campare the MP Header in the Volare to The Clifford long tubes in the dart.
I will let you know how it all works out.
Lou, I will have to check the timing - I did Dial it Back a bit and I am using a medium spring instead of the Super Light One.
I set it few months a go, but I cannot remember as to what setting I set it to.
