It is currently Tue May 19, 2026 7:53 am
 Post subject: 8 1/4 A Body Rear
PostPosted: Fri Oct 20, 2006 3:48 pm
I would like to put an 8 1/4 surgrip rear on my 66 drag Cuda. What would be a good donor car? I not looking to do a Major rebuild on the axles etc. The motor and tranny a targeted to be a 12sec car. Also if anyone has any gear ratio reccomendations.
thanks
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Fri Oct 20, 2006 7:05 pm
A Volare or Aspen might have what you are looking for, although beware of those that have gears higher than 2.76. They have a different housing and can not be geared lower. I would check mid 70's mainly, that is before the gear ratios got ridiculoulsy tall.
If you plan on narrowing your rear, then most 1980s Dodge pickups have an 8 1/4 or 9 1/4. 250's and 350's were 8 lug models though, stay away from those.
Or you could get a 9 inch Ford. You'll never break it.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Sat Oct 21, 2006 1:28 am
For a 12 sec car, depending on tire size, you will want a ratio of about 4.30-4.56-4.88
 Post subject: The bolt in...
PostPosted: Sat Oct 21, 2006 6:05 am
If you get lucky to find one:
Any 1973-1976 Duster,Dart, Valiant, Dart Sport with a 10 bolt round rear cover will be a good core...if the car is OEM and has disc brakes and a 3 speed manual on the floor then it will most likely have the 8 1/4" if it's still all original.
PostPosted: Sat Oct 21, 2006 6:20 am
There are several listed in car-part.com. Look for a 74 Dart with a 10-bolt rear axle.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sun Oct 22, 2006 6:13 am
Thanks for all the info Guys. My Cudas are on the way here and its time to get started finding parts.
Frank :D
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Mon Oct 23, 2006 9:46 pm
Set the car up with a Mopar 8 3/4 and you will be glad you did.
PostPosted: Tue Oct 24, 2006 6:53 am
Thanks Doc If I can find /afford one.
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Thu Oct 26, 2006 5:51 pm
? when replacing a 7 1/4 with a 8 1/4 from an A-body the driveshaft will need to be shorten. Does anyone know how much for my Barracuda? Also is the u-joint the same for the 8 1/4?
