It is currently Mon Nov 16, 2026 1:24 pm
 Post subject: rear brakes
PostPosted: Mon Oct 23, 2006 9:17 pm
im changing the rear axles to the bbp and i have the correct axles and drum hats but the car has 9 in. rear drums, small bolt pattern. can i use the shoes and hardware off of the 9in. drums and just transfer everything over(shoes,springs,wheel cylinders,ect.) to the 10 in. drum backing plate?or does the 10in. use a different shoe?also i didnt get the charger stuff, went to a different yard and found a 70's valiant and stole everything off of that :D
1975 Plymouth Duster,225/6 2bbl. and duels, 904, 7 1/4
1986 Dodge Charger Shelby, 2.2 Turbo I, A525
PostPosted: Mon Oct 23, 2006 10:34 pm
You can't use the axles, backing plates or anything else you bought on the small bolt pattern 7 1/4. The 7 1/4 housing was made narrower to accommodate the 2 1/2" wide brakes. This means the axle bearing to flange dimension is different from the small bolt pattern axles to get the same overall track width. Of course you can't use a 9" shoe in a 10" drum. You need to go back and get the axle housing out of that Valiant. Should have bought the whole axle assembly first time 'round.
PostPosted: Tue Oct 24, 2006 5:08 pm
whoa there,, the newer 10" brakes were also 2-1/2" wide. I'm assuming its on a 75 duster going by your sig. Joshy is right. youd have probably been better getting the whole rear out of the JY. But, on a 75 model, being that both the 9 or 10" shoes woulda been the same width, your axle housing will probably be fine.
PostPosted: Tue Oct 24, 2006 6:20 pm
yea i wanted to pull the whole assembly outta the junkyard, but after taking off the cover and seeing the trashed spider gears :( i decided to go back this weekend and pull off all the brake stuff, besides i forgot the proportioning valve off the valient(it was a 73-76 model) :oops: , thanks all
PostPosted: Thu Oct 26, 2006 11:30 am
on a related note, is there any small things that are needed to use the K-H disc brake stuff? things like bearings, hoses,different seals things like that? the only reason i ask, is because i asked my auto shop teacher if i could do it in class and he asked me to make sure that i had EVERYTHING and that i wasent going to be missing anything so is there any small items that need changing or are needed?
Users browsing this forum: Ahrefs [Bot] and 1 guest
