It is currently Fri May 15, 2026 4:33 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
 Post subject: OS valves
PostPosted: Tue Jan 01, 2002 4:47 pm
Where can I find oversized valves that aren't as expensive as the ones MP sells? I would try stock replacement valves.
catfan@radiks.net
 Post subject: Re: OS valves
PostPosted: Tue Jan 01, 2002 8:36 pm
: Where can I find oversized valves that aren't
: as expensive as the ones MP sells? I would
: try stock replacement valves.
Egge Machine is one source, check the the "Slantsickness" article (Nov. 2000) for info.
Use the search function for more info.
PostPosted: Sat Jan 12, 2002 3:39 pm
I used Phord windsor 1.78" intakes and small block Shivvy 1.50" exhaust in my "Screamin' Six" /6. They are about .100" longer than stock and have 11/32" stems. And I used stock replacement 340 springs with dampers.
