It is currently Mon Dec 02, 2024 4:54 pm
Post new topic  Reply to topic  [ 17 posts ]  Go to page Previous 1 2
PostPosted: Fri Oct 27, 2006 6:37 am
I can't see how a set of small tube long primary headers will hurt it?
They'll reduce low-end torque and driveability, which is what you want to maximise in a truck application.
I disagree with that as well Dan. Headers vastly improved power across the board on my slant, even with the 2 bbl (BBD) I had at the time.
As to the loss of intake manifold heat: I drove around in Alaska with headers on my slant, and it was never a problem. Warmup may or may not have taken longer, I never timed it. When it is -20*F the truck was going to be running for 15 minutes before I went anywhere anyway. I never had carb icing issues in Alaska, as the humidity was too low (read, usually 0% ). I did have my carb ice up a handful of times in Montana, over the course of three years. But, in those instances, a 3 minute stop at a convenience store for coffee provided enough heat soak to thaw the carb out. $0.02
PostPosted: Sat Oct 28, 2006 5:02 am
On the topic of headers... Do the short tube ones (ala Clifford) provide much benefit, or are they too short to have any tuning value?
-Mac
