It is currently Fri May 15, 2026 2:48 pm
 Post subject: axle swap on 8 3/4
PostPosted: Fri Oct 27, 2006 7:11 pm
can i pull the axles out of my 8 3/4 A body rear end with small bolt pattern and put in axles from an 8 3/4 A body with large bolt pattern with no problems? thanks GRT
 Post subject: Re: axle swap on 8 3/4
PostPosted: Fri Oct 27, 2006 7:37 pm
All "A" body 8 3/4 rears are SBP. "A" body never was made with a LBP 8 3/4 rear.
PostPosted: Fri Oct 27, 2006 7:41 pm
No axles are the right length. Also the SBP 8 3/4 axles use narrower brakes so if you cut down say C-body wagon or D100 8 3/4 axles to fit then the overall width is about 3/4" wider. Been there, done that.
PostPosted: Fri Oct 27, 2006 7:44 pm
contact Moser http://moserengineering.com/
PostPosted: Sat Oct 28, 2006 12:44 am
You can take your axles and have them welded and redrilled for LBP. Or you might get lucky and find a set someone has already cut to fit or done the welding. They just have to be the right lenth and offset for the brakes. Also I thing the left & right axle are diff lenths so if measuring a set be sure to check the proper side. I have seen people run B body rears in A bodys. By the way you ask your question it almost sounds like you have a nother rear the get the axles out of. Just measure them to see if they fit. Lenth and brake spacing is all you need to worry about because all the bearing sizes and mounting hardwear is basically the same.
Jess
PostPosted: Sat Oct 28, 2006 9:19 am
Oh doesnt the 73 up A bodys have big bolt pattern wheels anyway. Or did they quit making the 8 3/4 by then.
Jess
PostPosted: Sat Oct 28, 2006 10:42 am
They used the 8.25 axle assembly in those years.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sat Oct 28, 2006 11:42 am
The SBP 8.75 axles don't require welding to redrill for LBP.
Use screw in studs instead of the press in studs with the large shoulder.
Have a machine shop use a lathe to scribe a 4.5" circle and then drill 5 holes 72* apart and tap them for 1/2" fine thread (1/2 x 20?).
Aftermarket axles are best to use, mostly because you change over to the common 10" or 11" Mopar rear brakes and ditch the 10" A body brakes that are getting hard and expensive to find parts for.
Slant Cecil
Users browsing this forum: No registered users and 15 guests
