It is currently Wed Nov 18, 2026 5:05 am
PostPosted: Sat Oct 28, 2006 10:45 am
I was thinking about modifying the windshield wiper switch to have more than 3 speeds. It'd be nice to accommodate for mist and other light precipitation. I'd like to rig in a more modern switch with a delay between motor rotations. The appearance must be stock.
Any ideas or experience?
Just a thought...
Vehicle is 75 Plymouth Valiant /6 Sedan
___________________________________
Some headers and a super6... She'll be alright
PostPosted: Sat Oct 28, 2006 12:38 pm
Earlier cars like my '66 Dart had variable speed wipers. Sounds like you want modern intermittent wipers. You can retrofit them, but the control box hardly looks stock. Are you daily driving a show car or what?
PostPosted: Sun Oct 29, 2006 12:11 am
correcting myself:
intermittent wipers would be a better description
any ideas?
PostPosted: Sun Oct 29, 2006 6:57 am
There are several aftermarket intermittent wipe controllers available. There're the cheesy Taiwanese ones from JC Witless, and there are good ones from Bosch and Hella for about, if I remember correctly, $65. Some people have made their own.
PostPosted: Sun Oct 29, 2006 10:42 pm
I Made One Using The Guts Of A control Module Out Of A Newer Car... I Think It Was A New Yorker ( The J / M Body; Not A K-Car ) I Lucked Out By Finding All The Wiring Diagrams I Could Ever Hope For At A Public Library, And Went To Town With A Soldering Gun.
Stock Look, Intermittent Blades. I Was Quite Proud Of Myself.. 8)
Make Sure To Get The Wiring Diagrams For Both Your Car And The Donor
Seth
PostPosted: Mon Oct 30, 2006 10:47 am
It's going to be a daily driver and the car will look entirely stock with the exception of the engine compartment. I intend on hiding the controls and leaving the disconnected stock switch in the cluster. Intermittent wipers sounds like a fun project. Off to the junkyard!
PostPosted: Mon Oct 30, 2006 11:39 am
Don't Clutter Up The Space Between The Dash And Firewall!, Don't Have A Control Panel In Your Dash Purely For Esthetics!, Don't Force Yourself To Give Your Insturment Cluster A Reacharound Just To Operate The Wipers! ( Esp. While You're Driving Around In The Rain! ) Use The Junk Yard Parts To Alter Your Exsisting Panel Into A Functioning Intermittent Module. It Does Take Some Planning As Far As The Wiring Is Concerned, As Well As Some Patience With Building Small Components; But Is WELL Worth The Effort! User Friendly, Yet Visually Appealing Wiper Controlls.
Oh, I Forgot To Mention In My Other Reply, That You Will Want To Snag The Wiper Motor In Addition To The Control Head From The Donor Car..
PostPosted: Mon Oct 30, 2006 12:14 pm
Another Don't... Don't capitalize every word of your post. Not only does it make it harder to read, I imagine it's a pain in the neck to type that way. :lol:
Used to own:
'82 Dodge D150
Erson 270 Cam, O/S valves, mild port work, ~9.5:1 compression
Currently fighting with an '85 VW Cabriolet
My other passion
PostPosted: Mon Oct 30, 2006 12:33 pm
at least it wasn't all CAPS................. :lol:
PostPosted: Mon Oct 30, 2006 1:59 pm
Sorry, it's a habbit i picked up as a sailmaker.... you wouldent belive howmany times I had to use the 'backspace' key to accomplish this note! :oops:
PostPosted: Mon Oct 30, 2006 4:13 pm
IT'S GREAT WHEN PEOPLE USE ALL CAPS AND BOLD THAT WAY THEY CAN SCREAM AT PEOPLE THEY DON'T KNOW USING THEIR COMPUTERS. YAAAAAAAH
PostPosted: Mon Oct 30, 2006 4:20 pm
I thought that writing style looked pretty cool myself...sort of fancy.
I am in the process of changing out the gauges in my Dart for aftermarket gauges, but I am retaining all of the old switches, to at least try them (or until I can find their functional equivalents). One thing that made me want to keep the old switches was the trouble I was having finding new switches with the exact same characteristics. I really did want to keep more of an '60s look, too. It's cool to hear about people retrofitting new electronics in the old dashes and keeping the old look. Got any pictures of your work?
'68 Dodge Dart 4dr Sedan
PostPosted: Mon Oct 30, 2006 9:35 pm
I'm Currently Doing the Same. My Light Switch, When I Turn it All the Way Up for the Brightest Dash Lights, the Dash Lights Go Off. I found an OEM style replacement Light switch at Kragen, it was $13. I haven't installed it yet, so I can't testify to its quality, but it couldn't be much worse than a sticky 30+ year old switch. I did put in a gas gauge this weekend though (in a tempory spot), and it works. No more running out of gas.
PostPosted: Tue Oct 31, 2006 7:53 am
I just received the new (Feb. '07) Mopar Action in the mail, and there is an article about fitting aftermarket gauges, etc. into an A-body. Just a FYI.
PostPosted: Tue Oct 31, 2006 10:15 am
Thanks for the info, will have to check it out.
