It is currently Tue May 19, 2026 3:29 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 2 posts ]
PostPosted: Sun Jan 06, 2002 6:32 pm
Thought I'd fire-up the motor for the first time today, but no luck.
After filling all the fluids, I saw something dripping under the car. It was water coming from the head, not the head gasket, but from the manifold studs. I followed the instructions in the repair books (Chilton's and Dodge Service Manual). We just tightened them to 10 ft/lbs. Did I forget something? Was I supposed to put sealant on them?
I pulled the manifolds back off and removed the studs. Any advice on what to do to keep this from happening again?
Thanks!
benwa23@hotmail.com
PostPosted: Sun Jan 06, 2002 7:32 pm
You can put sealant on the studs before installing them and that will usually stop it. I personally think most people get so mad that they forgot to put the sealer on them they just let them rust themselves shut :-) I forgot to seal them on my 360 last week and I just drove it 30-40 miles and it stopped leaking right away. Since you have already pulled the studs, I would put some sealer on them and put it all back together.
My Mopar Site
Mark71GTX@hotmail.com
