It is currently Tue Nov 17, 2026 12:05 pm
PostPosted: Mon Nov 13, 2006 4:27 pm
What do you think the very unstable or leave the ground speed would be for my 67 Barracuda if lack of power were not a factor?
PostPosted: Mon Nov 13, 2006 5:12 pm
Too many variables. You could however push it over a cliff. :D
The Old Goat '83 D150 225-2
AKA Ice Titan
PostPosted: Mon Nov 13, 2006 5:16 pm
Just looking for an idea.
PostPosted: Mon Nov 13, 2006 5:39 pm
Strap a JATO unit to the roof, set it alight, and find out for us.
PostPosted: Mon Nov 13, 2006 5:56 pm
That'd solve the Mouse in the Headliner problem.
PostPosted: Mon Nov 13, 2006 6:03 pm
I know my 94 Altima would start darting back and forth at around 85 MPH. I am not a fan at all of high speeds even if the car is stabil.
I relieve anyone giving a MPH of liability. :D
PostPosted: Mon Nov 13, 2006 6:24 pm
my car wich is based upon the same body style and year as yours, is very stable at high cruise speed, say 100 mph +/- 10 mph. Fuel mileage cruising at that speed sucks, but the car can see steady 130 mph before it starts kinda do whatever she feels like doing over the pavement. I¡'m driving with PS (not BS, heehhe :wink: ) but have reworked the suspension in this fashion: 1" torsion bars, firm socks, front and rear sway bars, 4º advance on both front wheels, .5º positive camber on drivers side front wheel, .75º on passg -or reverse, i don't recall right now- I have 8" rims with 245/60/14's on the back, 3" backspacing, and 205/60/14's on the front, 6" rims with 3" backspacing. idler arm bushing is delrin, LCA's are special grilon stock loaded with MoSO2 (molybdene disulphure) UCA's bushings are rubber, and the strut rods are threaded in a way that allows for installing a nut from behind in adittion to the nut that drives the LCA's forward, to prevent walking. I usually end up cruising @ 90-100 with a 3.07 dana 44 rear end, but still have more pedal.
Juan Ignacio Caino
PostPosted: Mon Nov 13, 2006 6:33 pm
Very nice info.
Thank You. 8)
I will be having an alignment soon.
Is there any additional info I should give them?
PostPosted: Mon Nov 13, 2006 7:17 pm
Before my Duster expired I had the speedometer pegged out (100) one time and it was almost uncontrallable. The whole car shook so bad that the glovebox door came open and the rearview mirror turned around backwards. My ex-girlfriend thought it was hilarious even though we were probably going to die if I lost control. I always knew she was a little off.
I never went over 80 with that car again after that.
I am scared to try out my Miata (WAY too light and I prize it too much).
I look back at the all the crap I did and I say, god I was dumba##. :roll:
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Tue Nov 14, 2006 5:05 am
you gotta have your car in top shape before try'n wind up the speedo... really gotta work on the car (and tires/brakes/suspension) before playing Mr. Smartypants with the gas pedal. (of course, I don't do it all the time, meaning, playing by my rule and being safe instead of plain old wacko)
my other car (VW GOLF MPEFI 1.8) starts to get cranky @ 80 MPH... and the top speed is around 120 (depending on the cargo, sometimes I can't get it to reach 110, let alone 120) as notorious good mileage and low end I get from that little piece of bad quality steel and plastic, I miss the lush mid-high power from my not so wild slant... and modern suspensions (they're supposed to be really improved over our cars suspensions? ) are not as easily modified as good old strut rod, UCA, LCA and torsion bar suspensions.
Juan Ignacio Caino
PostPosted: Tue Nov 14, 2006 6:01 am
Online
Well, my 64 Dart and 66 Valiant are quite stable up to around 130MPH. I guess the V's only been up to around 115 so far. I set the cars up with a little downward rake. Tight suspension and good tires help A LOT. I've had my 68 Dart to about 120 and to 110-115 plenty of times - pretty stable too.
PostPosted: Tue Nov 14, 2006 10:49 am
The SS/AA '68 Barracudas are running over 150mph, with skinny front tires, and rear tires with 6lbs of air and thin sidewalls!
The only time they head for the sky is off the starting line.
Slant Cecil
PostPosted: Tue Nov 14, 2006 1:33 pm
My 64 was stable at an indicated 100 (probably 90)....... it ran out of breath (1bbl)
F/R antiroll bars
F/R KYBs
195/70 14s
PostPosted: Tue Nov 14, 2006 3:25 pm
SSRN National Champion
According to my wind tunnel expert Mr Red Neckerson who has a degree at little Ga Tech he caculated it would be about 55mph caught in a f-3 tornado. Yep that would pick er up. If any more aero questions arise Mr Neckerson said they would be a small fee say a six pack. Thanks Possum
It Aint Over Until I Win
PostPosted: Tue Nov 14, 2006 4:35 pm
According to my wind tunnel expert Mr Red Neckerson who has a degree at little Ga Tech he caculated it would be about 55mph caught in a f-3 torando. Yep that would pick er up. If any more aero questions arise Mr Neckerson said they would be a small fee say a six pack. Thanks Possum
heheheheheheehh :twisted: :twisted:
Juan Ignacio Caino
