It is currently Mon May 18, 2026 9:55 pm
PostPosted: Tue Nov 14, 2006 2:50 pm
Hey all, I'm going to get a set of Cragar Soft 8s for my 74 Dart Custom, but I know absolutely nothing about wheels. I'm going to get the 15x7s, but I'm quite confused by the offset and backspacing options. What would be best? Going to get them from Summit because I get a discount, so here's the link:
Cragar Soft 8s
I also have no idea what size tire to run on these. Any help would be appreciated. Thanks.
PostPosted: Tue Nov 14, 2006 4:49 pm
Small or big bolt pattern on your Dart? Assuming a large bolt pattern disc brake car you want a 15x7" wheel with 4.25" backspace. So the CRR-3975712P is your wheel. BTW, the factory 15x7" wheels are 4.25" backspace which is +6mm offset. I would run 215 or 225/60R15s on all 4 corners myself.
PostPosted: Tue Nov 14, 2006 5:42 pm
Thanks alot. And yeah, the BBP. Found that out not to long ago, hence the decision to get some wheels. Plus, that frees up the steelies for snow tires. Thanks again.
