It is currently Sat Nov 14, 2026 2:15 am
PostPosted: Mon Nov 06, 2006 5:23 pm
Where can I get a clutch fork return spring for a 1980 D-150 truck with a A-833 OD transmission and a Slant Six? Everyone I find is too short. I need one about 3 1/2" not the 2 1/2" one I am being offered. I see some on some websites that are for big blocks. Someone help, please!!
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
PostPosted: Wed Nov 15, 2006 8:27 am
Hey BWHite,
I too needed one for my truck when I did the 833 swap. I was and am using a wilwood pull cylinder to the fork but don't see why that would make any difference. THE spring I got works fine and is made with one hook end and a 5 inch long straight end that you insert to what tension you want and bend into a final hook. IN other words one stock hook, one hook you can make. Got it a local parts place. I can look up the number and all but I betcha most places may have the same thing. I think it was about $5.50.
rock
'64d100
