It is currently Fri May 15, 2026 4:27 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 8 posts ]
 Post subject: supersixcarb
PostPosted: Wed Jan 09, 2002 9:51 pm
Does anyone know where I actually find a carter super six carb - I see them mentioned everywhere and that I should check boneyards - but ya know - I have and they aint around!!
Thanks! Even new would be great!
highwater@juno.com
 Post subject: Re: supersixcarb
PostPosted: Thu Jan 10, 2002 5:17 am
: Does anyone know where I actually find a carter
: super six carb - I see them mentioned
: everywhere and that I should check boneyards
: - but ya know - I have and they aint
: around!!
: Thanks! Even new would be great!
When I did my conversion on my 73 Duster, I just got a Carter 2bbl from a 73 318. That way it would have the same vacuum ports, etc.
ktbarnwell1@juno.com
PostPosted: Thu Jan 10, 2002 9:20 pm
Kragen Auto,Carter bbd off of a early(no smog)318 mopar.Get the one rebuilt by Holley,cost me $120.00.Good Luck!!
johnfzirbel@mindspring.com
PostPosted: Sat Jan 12, 2002 5:06 pm
: around!!
I found a bunch in a yard in Florida, bought two that still had the tag on them and had one of thew rebuild. I believe they are more readily available on the east coast. Donors are Aspens and Volares.
Chuck
webmaster@omnipages.com
PostPosted: Sat Jan 12, 2002 5:33 pm
boomerwagon i have a holley supersix carb and manifold that i ran on my car 3 years ago. the carb will probbaly have to be rebuilt but it ran good while on the car. the car picked up about .2 in the 1/8. you can have the carb if you can pay for shiping or see me at one of the /6 races thanks ron parker
rpracing@catt.com
PostPosted: Sun Jan 13, 2002 9:58 am
Chuck, I think you are more than correct!
I can't find a 2 barrel anywhere here in northern CA. Only one I have been able to get ahold of is a Rochester that is loaded with connections and holes that I can only guess as to what connects to them! I did find a number on it and it's listed in my Chiltons but no diagrams as to what connects where. Since I am running a '69 vehicle I only need to connect the fuel and a line for the vacuum advance on the distributor and a line to the PCV and that leaves about 3 more holes in the damn thing than I need!
Oh well, guess I will just keep looking and hoping to find a good 2 barrel or just go looking for a 390 to put on it.
Later,
Dan
"I may be slow, but at least I'm not very fast!"
PostPosted: Sun Jan 13, 2002 4:25 pm
OK, who wants my super six carb? Manifold? I am in norther ca. It's a naked 49 stater from texas. I was thinking $40/best offer for the carb and same for the manifold. Would recomend a dual stage webber instead, or the 390 (yeah, I like the 390!!!!!!!!!!)
: Chuck, I think you are more than correct!
: I can't find a 2 barrel anywhere here in
: northern CA. Only one I have been able to
: get ahold of is a Rochester that is loaded
: with connections and holes that I can only
: guess as to what connects to them! I did
: find a number on it and it's listed in my
: Chiltons but no diagrams as to what connects
: where. Since I am running a '69 vehicle I
: only need to connect the fuel and a line for
: the vacuum advance on the distributor and a
: line to the PCV and that leaves about 3 more
: holes in the damn thing than I need!
: Oh well, guess I will just keep looking and
: hoping to find a good 2 barrel or just go
: looking for a 390 to put on it.
: Later,
: Dan
: "I may be slow, but at least I'm not very
: fast!"
Richard-c@e-d-a.com
PostPosted: Sun Jan 13, 2002 4:29 pm
: OK, who wants my super six carb? Manifold? I am
: in norther ca. It's a naked 49 stater from
: texas. I was thinking $40/best offer for the
: carb and same for the manifold. Make an offer, I might not refuse it.
Would
: recomend a dual stage webber instead, or the
: 390 (yeah, I like the 390!!!!!!!!!!)
OOPS <A HREF="mailto:Richard-c@e-d-a.com">Richard-c@e-d-a.com</A>
Richard-c@e-d-a.com
