It is currently Tue Nov 17, 2026 2:02 am
PostPosted: Tue Nov 14, 2006 9:11 am
I have found an online calculator that will figure engine RPM based on tire size, rear gear, trans ratio, and speed. For example 60MPH with 3rd gear (1:1), a rear gear of 3.55:1 and a 26 inch tall tire yeilds 2753 RPM. I am usuming that this calculator does not take in to account for torque converter slipage.
How much slipage would you think there is?
I don't want to cruise with an RPM over 3000.
PostPosted: Tue Nov 14, 2006 9:13 am
That would depend on what converter you use and what it actually stalls at in your car.
PostPosted: Tue Nov 14, 2006 10:04 am
Lets say it's a stock 2000 stall converter.
And lets say its an aftermarket 2800 stall converter.
Also if I have a lockup style 904 are there lockup aftermarket converters and do they lockup? I have heard about converters for lockup type trans that don't lockup.
PostPosted: Tue Nov 14, 2006 1:30 pm
I have an old DeskTop Drag Program and it assumes the following slip percentages for various stall speeds:
1200 3%
1800 4%
2500 5%
3500 6%
4000 7%
4500 7%
5000 7%
PostPosted: Tue Nov 14, 2006 1:31 pm
At 2800 RPM, I would guess the 2000 stall converter would slip 5-8% and the 2800 stall would slip maybe 9-12%.
PostPosted: Thu Nov 16, 2006 9:10 am
PostPosted: Thu Nov 16, 2006 9:56 am
Don't forget that the rear axle ratio will affect converter slippage. A lower (numerical) axle ratio will require more torque for a given road load (less RPM requires more torque for the same horsepower) increasing slippage. The lower RPM also put the converter into a less efficient and more slip and heat producing operating range. This is why you do not want to have a cruise RPM below the stall speed of the converter. You end up putting a ton of heat into the fluid. That heat is just wasted fuel and if the trans cooler is insufficient, a wasted transmission. One more thing. Smaller converters are more efficient at high stall speeds than large ones.
PostPosted: Fri Nov 17, 2006 5:45 pm
SSRN National Champion
Are these guys good or what. Thanks Ron Parker :D
It Aint Over Until I Win
PostPosted: Fri Nov 17, 2006 5:55 pm
PostPosted: Sat Nov 18, 2006 9:04 am
Yes, you can get high stall lockup converters. They are more money of course. Google is your friend.
