It is currently Sun May 17, 2026 2:02 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 6 posts ]
 Post subject: pushrods
PostPosted: Tue Jan 15, 2002 6:03 pm
If you mill .100 off your head new head gasket is about .020 thicker than stock wouldnt your pushrods simply need to be made about .080 shorter than stock?
melam@nxs.net
 Post subject: Re: pushrods
PostPosted: Tue Jan 15, 2002 9:11 pm
: If you mill .100 off your head new head gasket
: is about .020 thicker than stock wouldnt
: your pushrods simply need to be made about
: .080 shorter than stock?
Did you change your camshaft? Or is this the only change you made?
damuel@kalama.com
PostPosted: Tue Jan 15, 2002 10:01 pm
the hight of the valve stem makes a difference too
slantsix@netzero.net
 Post subject: Re: Custom Pushrods
PostPosted: Wed Jan 16, 2002 9:49 am
Always "mock-up" your combo and take actual measurements before ordering a custom set of pushrods.
Many times things will "stack-up" right and the stock length will work fine.
PostPosted: Wed Jan 16, 2002 10:11 am
: Did you change your camshaft? Or is this the
: only change you made?
I changed it to 252 comp cams mild cam I think .435 lift. But Lift should'nt afect pushrod lengh should it? Thanks for your response.
melam@nxs.net
PostPosted: Wed Jan 16, 2002 10:14 pm
: I changed it to 252 comp cams mild cam I think
: .435 lift. But Lift should'nt afect pushrod
: lengh should it? Thanks for your response.
When you install a larger cam shaft than stock, the base circle of the cam also changes. The only way to be sure on the length is to assemble the engine and check it. This way you only have to buy one set of push rods.
damuel@kalama.com
