It is currently Tue May 19, 2026 12:09 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 6 posts ]
PostPosted: Fri Jan 18, 2002 6:50 am
Hi,
Looking through my ARP price list last night and I noticed two versions of rod bolts, 142-6001 and 142-6002, no real difference in the description, and the price is similar. I don't have an ARP catalog, so I don't know what it says.
Anyone know the difference in 6001/6002?
thanks,
mark
mldingba@collins.rockwell.com
PostPosted: Fri Jan 18, 2002 11:25 am
The difference is in the bolt head. p/n 142-6001 has a round head with 1 flat side. 142-6002 has 2 flat sides opposite each other. This is per the 2001 ARP catalog.
motorhedfred
: Hi,
: Looking through my ARP price list last night
: and I noticed two versions of rod bolts,
: 142-6001 and 142-6002, no real difference in
: the description, and the price is similar. I
: don't have an ARP catalog, so I don't know
: what it says.
: Anyone know the difference in 6001/6002?
: thanks,
: mark
motorhedfred@yahoo.com
 Post subject: applications?
PostPosted: Fri Jan 18, 2002 1:18 pm
: The difference is in the bolt head. p/n
: 142-6001 has a round head with 1 flat side.
: 142-6002 has 2 flat sides opposite each
: other. This is per the 2001 ARP catalog.
: motorhedfred
Thanks!
Is the rod bolt with an extra flat for a special application? Aftermarket rod? Stroker crank? Just a different head design?
Is one better than the other?
thanks again,
mark
 Post subject: Re: applications?
PostPosted: Fri Jan 18, 2002 2:52 pm
I really couldn't tell you. It's up to you to figure out which one you need by seeing what head shape your rod bolts have.
motorhedfred
: Thanks!
: Is the rod bolt with an extra flat for a
: special application? Aftermarket rod?
: Stroker crank? Just a different head design?
: Is one better than the other?
: thanks again,
: mark
PostPosted: Fri Jan 18, 2002 3:56 pm
I have always used the 142-6001 with the one flat.
These bolts always seem to need some head clearance work to fit / fully seat on the SL6 con rod. They do a good job of spreading the load out evenly around the bolt hole area.
My guess is that the "2 flat side" bolts *may* fit without the additional bolt head clearance work but I have never used the 142-6002, has anyone out there used them?
PostPosted: Sun Jan 20, 2002 6:08 am
I will have to see which ones I have in my extra part box. I have always used the small block bolts with no problem. then the slant six bolts came out so I ordered some and they were wrong for my application.
Will
: I have always used the 142-6001 with the one
: flat.
: These bolts always seem to need some head
: clearance work to fit / fully seat on the
: SL6 con rod. They do a good job of spreading
: the load out evenly around the bolt hole
: area.
: My guess is that the "2 flat side"
: bolts *may* fit without the additional bolt
: head clearance work but I have never used
: the 142-6002, has anyone out there used
: them?
: DD
slantsix@netzero.net
