It is currently Sat Nov 14, 2026 1:15 am
 Post subject: key replacement
PostPosted: Sat Dec 09, 2006 10:19 pm
My only door/ignition key for my 64 Dart just broke off. Any suggestions out there for the cheapest way to get back going? Are there numbers out there I can get to have a key made from? Other suggestions to avoid replacing locks and ignition?
Many thanks,
Jeremy
PostPosted: Sun Dec 10, 2006 1:24 am
Assuming you don't want to re-core everything, call a locksmith.
Used to own:
'82 Dodge D150
Erson 270 Cam, O/S valves, mild port work, ~9.5:1 compression
Currently fighting with an '85 VW Cabriolet
My other passion
PostPosted: Sun Dec 10, 2006 4:31 am
Depends on where along its length the key actually broke. I once brought a key into the hardware store in two pieces. They were able to get it into the key grinder and fashion a new one for me. $1.49.
BTW- You'll need to go to a hardware store that has been around a long time, then find the oldest fellow there to do it. Most of the new big-box stores will just say no...
If that works then make a spare!!!
:D
-Mac
PostPosted: Sun Dec 10, 2006 6:28 am
I've seen my Dad make a new key by hand. He clamped the old one and new blank together in a vise then used a triangular file to cut the teeth to match the old pattern. It was slow and tedious but it worked.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sun Dec 10, 2006 9:10 am
I haven't tried this myself but after reading this, I have the strange desire to try it!
Russ
PostPosted: Sun Dec 10, 2006 9:29 am
That's really all the machines do at the hardware store... they simply run along the teeth of your original with a guide, the guide is attached to a cutting wheel that forms the blank.
Notice that the rest of the form factor on the blank looks exactly like your original key (side grooves, length, etc).
PostPosted: Sun Dec 10, 2006 1:31 pm
Yeah but I'll bet that the machine has a lot more patience than myself, lol! :lol:
Russ
