It is currently Mon Nov 23, 2026 9:22 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 2 posts ]
 Post subject: Block ?
PostPosted: Mon Jan 21, 2002 6:08 pm
Hi Guys
I've got 3 blocks to chose from for my rebuild don't know the years but 2 have 5 freeze plugs
1 has 3 is one better than the other? each has a crank I "think" 2 are cast and one is steel I think the later block is the steel crank
Thanks for any help
mrmopar@greganti.com
 Post subject: Re: Which SL6 Block ?
PostPosted: Mon Jan 21, 2002 7:19 pm
: Hi Guys
: I've got 3 blocks to chose from for my rebuild
: don't know the years but 2 have 5 freeze
: plugs
: 1 has 3 is one better than the other? each has
: a crank I "think" 2 are cast and
: one is steel I think the later block is the
: steel crank.
Read through the artilce on SL6 Blocks.
<A HREF="http://www.slantsix.org/articles/dutra-blocks/slant-blocks.htm">http://www.slantsix.org/articles/dutra-blocks/slant-blocks.htm</A>
I would go for the 5 freezeplug, forged steel crank one.
SL6 Block & Prep info. article
