It is currently Tue Jun 16, 2026 5:31 pm
 Post subject: Pics of carb, ???
PostPosted: Thu Dec 21, 2006 7:25 pm
PostPosted: Thu Dec 21, 2006 7:28 pm
Good, clear pictures. That vacuum port that connects to the ELB computer could be ported or manifold. Go ahead and proceed with your changeover, then see if that port has vacuum at low curb idle or not.
PostPosted: Thu Dec 21, 2006 7:29 pm
Ok the pics worked, Please note this is not my handywork. This is what I'm trying to make the most of ......
PostPosted: Thu Dec 21, 2006 7:43 pm
Can anyone tell me more about the carb? is it likely stock and what about the inop device that is relative to throttle rest/open. (manual trans, No a/c)....
PostPosted: Fri Dec 22, 2006 10:35 am
Sorry, if I'm changing the subject. I have noticed that your pcv looks different than normal. I have noticed this on 56 Dodge's truck also. He said his is working fine, its not shooting oil out of the breather or the dip stick. He told me " AC spark plug type PVC valve and the part number is CV-761-C. NAPA list two PVC valaves that will replace this PVC valve the part numbers are CRB29207 price 3.99 or part number MPF39207 price 1.99." Do you know what your application is for and/or do you have a # for it?
Your whole setup looks factory. The inop device that is relative to throttle rest/open? Now it just adjusts your truck idle.
82 D150 Slant6 Shorty
http://www.cardomain.com/ride/658846
PostPosted: Fri Dec 22, 2006 10:49 am
This is just a different style of PCV valve. The metal-body type like this fits and works just fine, same as the plastic-body original type.
The napaonline.com part numbers aren't quite the actual part numbers. "CRB 29207" is actually an Echlin 2-9207 valve, that is a quality unit. The "MPF39207" is actually a Mileage Plus 3-9207, that is NAPA's "Value line", i.e., Chinese crapola. Avoid it.
I'm not sure I understand the underlying question, here. Are we asking "Hey, what's that funny-lookin' PCV valve?"? Or are we asking for help in troubleshooting or building a PCV system?
PostPosted: Fri Dec 22, 2006 11:15 am
Around here I can get:
O'REILLY
MICROGARD - PCV Valve Part No: PCV163
FRAM - PCV Valve Part No: FV163DP -sp order
ACDELCO - PCV Valve Part No: CV761C -call
BORG-WARNER - PCV Valve Part No: PCV207 -call
AUTO ZONE
CHAMP PC51 -sp order
ADVANCED AUTO/PARTS AMERICA
Purolator Pcv Valve PV761
Fram PCV Valve FV163
Borg Warner PCV Valve: NASCAR PCV207 $7.99
This is what shows up on-line anyway.
The reason I'm looking so hard is that mine whistles. I tried a different one, but still whistles. I also tried the 1/8th hose into the pcv valve. It worked, but I don't think it is working for the engine. I get some oil out of the breather.
PostPosted: Fri Dec 22, 2006 11:43 am
Your carb looks very similar to what is currently on the goat, Carter BBD. Mine is not original. And I don't know how similar to the original it is. I do have pictures somewhere of the current one broken down.
Your wires on the ecu also looked a little chewed on.
The Old Goat '83 D150 225-2
AKA Ice Titan
PostPosted: Fri Dec 22, 2006 11:47 am
You've got a vacuum leak somewhere downstream of the PCV valve (hose, carburetor body, carb-to-manifold gasket).
...? Which 1/8" hose into the PCV valve?
PostPosted: Fri Dec 22, 2006 1:43 pm
It's just a 1'' to 1/2" piece of 1/8th" hose that is put inside the top part of the PCV valve. It's suppose to be a trick to stop it from whistling. Given to me by another.
I'll have to check and make sure there are no other leaks in the PCV system. Thanks for the info!
PostPosted: Fri Dec 22, 2006 4:02 pm
Um...this is a poor idea. Deliberately clogging the PCV valve is NOT the way to fix the problem. :roll:
PostPosted: Fri Dec 22, 2006 5:29 pm
If you need any exploded diagrams of the BBD, let me know. I have rebuilt more than a few.
Russ
