It is currently Tue Nov 17, 2026 5:33 am
 Post subject: Pinion question
PostPosted: Fri Dec 22, 2006 12:49 pm
This is a 63 Valiant /6 auto trans car:
My driveshaft angle is 1.5 - 1.75 degrees down
My rearend is 0 (zero) degrees
Will a 2.5 degree axle shim correct this pinion angle?
PostPosted: Fri Dec 22, 2006 8:41 pm
I installed the shims and now the nose of the rearend is tipped down at 3 degrees.
PostPosted: Fri Dec 22, 2006 8:50 pm
3° is on the "too much" side of things. These wedge-shims are best installed less-than-you-think-you-need at a time. Maybe back down to a 1° wedge?
PostPosted: Fri Dec 22, 2006 9:08 pm
What should the pinion angle (driveshaft+rearend) be for my car?
I think I was reading the wrong article...
Users browsing this forum: Amazon [Bot] and 3 guests
