It is currently Sun Oct 11, 2026 10:13 am
 Post subject: Motor mounts
PostPosted: Fri Dec 22, 2006 9:30 pm
The rubber bushings inside my motor mounts look worn out,does anyone make replacements? ANyone make Poly replacements? THe car is a 76 Dart.
Thanks
PostPosted: Fri Dec 22, 2006 9:48 pm
I found inserts from Autozone. I bought the whole mount with the insert already in them from them. I converted from the flat type to the spool. I notice that stuff rattles inside the passenger door at idle now. Are the spool type mounts firmer or are the inserts likely in wrong?
PostPosted: Sat Dec 23, 2006 7:22 am
I am not 100% sure, but the poly spool trans mount bushing may work in the motor mounts too. :shock:
PostPosted: Sat Dec 23, 2006 8:26 am
Where would I find the poly trans bushing? Do they have one to replace the mount for my A-833?
PostPosted: Sat Dec 23, 2006 8:57 am
I got one from Summit. It is for the '73 and up crossmember/mount. Mine was just the insert. :D
