It is currently Fri May 22, 2026 2:14 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
 Post subject: 500 cfm carb?
PostPosted: Mon Jan 28, 2002 7:28 pm
I currently have a Holley 390 carb on my /6, the carb is in need of rebuilding. Would the Edlebrook 500 be a good replacement or rebuild the Holley? It is a '66 from a Barracuda. It has the Offy Alum intake, Clifford Headers, and a Crane 720791 cam. It is in a '41 Dodge 1/2 ton Military 4x4 with a 4.89 rear end ratio, 35" tall tires and a 904 Auto Tranny. What a combo, huh.
Any input would be helpful.
Lew VB
PostPosted: Tue Jan 29, 2002 11:14 pm
The 390 should be enough to get you to 5000 RPM given your set-up.
Go with the 500 if you want to rev it higher then that.
: I currently have a Holley 390 carb on my /6,
: the carb is in need of rebuilding. Would the
: Edlebrook 500 be a good replacement or
: rebuild the Holley? It is a '66 from a
: Barracuda. It has the Offy Alum intake,
: Clifford Headers, and a Crane 720791 cam. It
: is in a '41 Dodge 1/2 ton Military 4x4 with
: a 4.89 rear end ratio, 35" tall tires
: and a 904 Auto Tranny. What a combo, huh.
: Any input would be helpful.
: Lew VB
PostPosted: Wed Jan 30, 2002 5:21 pm
: The 390 should be enough to get you to 5000 RPM
: given your set-up.
: Go with the 500 if you want to rev it higher
: then that.
: DD
I shift the auto tranny at 4000-4500 rpm when I'm "cleaning out the carbon". 60 mph is about 3100 rpm in drive. I guess I wondering if the 500cfm carb would be to much at the low end and it would gag when I stand on it from an idle. The turbo thing interests me and I'm thinking in a couple of years when I get done with the rest of the truck, I might explore the possibilities of a turbo and the 500 would lend itself to that pretty good, maybe?
Thanks for the help.
Lew VB
