It is currently Wed Nov 27, 2024 10:41 am
 Post subject: Rods/Pistons/198vs225
PostPosted: Fri Jan 05, 2007 11:16 am
Can I do a direct 225 swap with my 198 rods and pistons? Or will the pistons be too high?
'72 Duster 198 stock cam, 3:23's Hookers on jack stands for 8 years in the driveway
'79 Maxivan 360 Offy Qjet Comp RV cam/rusting in the driveway.
93 D350 160HP Cummins Auto :-( Dually Clubcab needs a injector pump
2005 Golden Couch Buick
PostPosted: Fri Jan 05, 2007 11:20 am
Oh yeah what is the rod lengths?
PostPosted: Fri Jan 05, 2007 11:24 am
198 rod is 7.006"
225 rod is 6.699"
Piston is the same on all slant-6s.
Use a stock piston with a 198 rod on a 225 crank and the piston will run into the cylinder head. You have to use a piston with a higher pin bore to run 198 rods on a 225 crank.
PostPosted: Fri Jan 05, 2007 11:35 am
Thanks Dan!
PostPosted: Fri Jan 05, 2007 11:50 am
You can use the 225 crank and rods and make a 225. :shock:
To use 198 rods you need 2.2, VW, or custom pistons. :D
Users browsing this forum: Bing [Bot], Google [Bot], Semrush [Bot] and 15 guests
