It is currently Sat Nov 21, 2026 4:10 am
PostPosted: Tue Jan 09, 2007 6:32 am
I know some of you own vans. How do you remove the engine? Does it come out the passenger door, or do you have to pull the whole front clip?
Jerry
PostPosted: Tue Jan 09, 2007 6:58 am
usually you have to pull the front end out (just the grill rad core support)but to do it this way you will nee an engine lift with a long reach (or an extension poll if you lift will support the weight) or you might be able to pull the k frame out and drop it out the bottom
PostPosted: Tue Jan 09, 2007 6:33 pm
What year van. Over the years I've done the motor on my 71 maxi twice. The first time young a dumb, I took the engine out the passenger side door. I'll never do that again. Takes about two hours to take the front end off then use a cherry picker to take the engine out the front. Be sure and work the lift chain short as you can, there is not much room in there.
66 Valiant, 225.
84 Van, 225.
71 Maxi-Van, 318
60 Valiant wagon, 225
87 Maxi-Van, 318 4spd
PostPosted: Tue Jan 09, 2007 11:18 pm
It's an 80-something Dodge Maxi-Van. The van is pretty much scrap, so I don't have to worry too much about damaging anything getting the engine out. What was the problem with going out the passenger door?
Jerry
PostPosted: Wed Jan 10, 2007 3:38 am
On the "B" series vans the engine is removed through the front-remove the bumper, grille, radiator etc. And as mentioned in an earlier post-keep the chain on the engine hoist as short as possible. Seems that I remember on V8 models removing the carb and manifolds (intake and exhaust) prior to removing the engine made clearance issues much easier to deal with.
Good Luck!
Todd
PostPosted: Wed Jan 10, 2007 5:11 am
Well if the van is junk i would just go crazy with a saws'all or go threw the door whatever works
PostPosted: Wed Jan 10, 2007 8:00 am
Working the cherry picker sometimes jacking the van up helps. Never pulled a slant. Just my 360's
PostPosted: Thu Jan 18, 2007 12:57 pm
As a matter of fact, Trucker, the van does have a 360 (I didn't want to mention that on this slant board) :oops:
I figured the process would be virtually the same, regardless.
Jerry
Users browsing this forum: DuckDuckGo [Bot] and 6 guests
