It is currently Sat Nov 21, 2026 3:20 pm
PostPosted: Wed Jan 10, 2007 8:24 pm
You may recall a recent post I put up about a cam installation issue, this has been resolved and I went on to build the rotating assembly today. I thought as I was building that the pistons seemed pretty far in but at that point had no idea what the spec should be, as I didn't check the deck height when I dissassembled the engine, so I started searching the moment I got home and after finding out that it should be in the area of .140, I decided to ride back to my shop and measure. I dont have any specializd tools for this but I suspect a dial caliper that has the shaft out the back should work and I get .420, yeah the pistons are nearly half an inch in the hole.
I took the block, head, crank, rods and pistons to a local shop that has a pretty good rep, They got me one new rod as my #6 was gone but said the turned MY crank. They also supplied and pressed new pistons, sealed power .030 244np.
I wonder if there is a crank or rod discrepancy in the engine, the block number is 2806830-3 which seems to decode correctly as a 1969 225 the
head does also. I haven't been able to find any markings on the crank except a large P and a large 4 the rods look pretty consistant with the numbers 2205554 on one side of all of them (I think) and various numbers on the other ex. 16025, 16016, 16029. How can I determine the origin of this crank? At what points can the stroke be measured? Please help......Sorry for the lengthy post.
.020 off the block .100 from head
Comp 264
904 Tranny
New Ebre-ting
http://s78.photobucket.com/albums/j103/edrod01/
