It is currently Sun Aug 16, 2026 6:16 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 7 posts ]
 Post subject: Ford 8 inch axle
PostPosted: Mon Feb 04, 2002 6:44 pm
I got a Ford 8 inch axle that was already setup for a 1970 Dart, the Dart was wrecked a couple months ago. I am getting this axle and driveshaft, with brakes. It looks like a smaller 9 inch Ford.
Are these a good replacement for a Chrysler 7 1/4 on a '64 Dart (assuming that a later tranny replaces the ball and trunion) ? What gear sets are available? Maybe you'll see this on Ebay :)
tkeith@mindspring.com
 Post subject: Re: Ford 8 inch axle
PostPosted: Mon Feb 04, 2002 9:03 pm
it is a decent rear. It gets used quite a bit in streetrod stuff as it is easy to swap gears and they are plentiful--at least when I was looking for one. They come with 28 spline axles. I had one in my falcon with a 3.25 gear. From what I recall, you can get quite a few gears for it too.
: I got a Ford 8 inch axle that was already setup
: for a 1970 Dart, the Dart was wrecked a
: couple months ago. I am getting this axle
: and driveshaft, with brakes. It looks like a
: smaller 9 inch Ford.
: Are these a good replacement for a Chrysler 7
: 1/4 on a '64 Dart (assuming that a later
: tranny replaces the ball and trunion) ? What
: gear sets are available? Maybe you'll see
: this on Ebay :)
glovert@southwestern.edu
PostPosted: Mon Feb 04, 2002 9:39 pm
: 7 1/4 on a '64 Dart (assuming that a later
: tranny replaces the ball and trunion)?
: What gear sets are available?
Just about anything is a "good replacement" for a Mopar 7 1/4 as far as I am concerned!
I have blow-up and swapped-out so many of those "weaklings".
The drop-out is a "plus" but there will be a bolt pattern difference to deal with.
I have no idea what gear ratios are offered for the 8 inch, sounds like a good question to ask on the fordsix.com board.
PostPosted: Tue Feb 05, 2002 8:04 am
: it is a decent rear. It gets used quite a bit
: in streetrod stuff as it is easy to swap
: gears and they are plentiful--at least when
: I was looking for one. They come with 28
: spline axles. I had one in my falcon with a
: 3.25 gear. From what I recall, you can get
: quite a few gears for it too.
I was just at a swap meet, and they had TONS of ratios for the 8" - 2.93, 3.25, 3.40, 3.56, 3.73, 3.90...
PostPosted: Tue Feb 05, 2002 2:23 pm
Tim i just give a friend an 8 inch ford that i was going to put in my car but did not. It was a 3.25 gear from a fairlane. I could not bring myself to put ford parts on a mopar. But there is nothing wrong with this setup. The width of the ford 8 inch and 71/4 were real close Gears are avalbale from several suppliers with good ratios Thanks Ron
rpracing@catt.com
PostPosted: Tue Feb 05, 2002 3:25 pm
I assumed the 8 inch axle has the same bolt pattern as 4 1/2" Dodge wheels. Hmmm, I didn't check the bolt pattern. The axle is under a '70 Dart with a 318 auto that had small bolt pattern front drums.
I saved my '64 Dart from the junkyard. A Ford axle isn't the worst thing that might happen to the car. There are several types of Ford axles with drop out center sections, the 8 looks to be light and strong, plus it looks right on the Dart.
: I have no idea what gear ratios are offered for
: the 8 inch, sounds like a good question to
: ask on the fordsix.com board.
: DD
PostPosted: Tue Feb 05, 2002 6:30 pm
I have a Ford with 225/6 running a 904 Torqueflite
with a 8 inch Ford, the only thing is you can get 4.11 but the next step is 4.56 as I remember. What I would like to have is 4.27 or 4.30, But not available. I do have the Mopar pentagram stamped on the rims (5 lug) so they are Mopar rims.
: I was just at a swap meet, and they had TONS of
: ratios for the 8" - 2.93, 3.25, 3.40,
: 3.56, 3.73, 3.90...
: Lou
dbjerklund@hotmail.com
