It is currently Fri Nov 20, 2026 6:20 pm
PostPosted: Sat Jan 20, 2007 11:06 am
I don't know how long my slant six Duster's damper / crank bolt has been missing. :)
Does anyone know if a v8 crank bolt will work such as the 2 1/4" Mopar Performance part? Or where to get the slant six bolt? I know that the damper is on there good - cause I just did a timing set and took it off and on. But I'd kinda like to make sure the damper stays on. :roll:
PostPosted: Sat Jan 20, 2007 12:18 pm
It probably never had a crank bolt, although you can add one if you like. The slant six dampers are designed to press fit on.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Sat Jan 20, 2007 12:31 pm
Thanks for the tip. I have a crank bolt on my other slant six car (Dart) and I think it had one when I bought it (used). The threads are the same as a v8 because the installer tool fits the same, but I didn't know how long a bolt I would need. I hadn't heard that they came without a crank bolt. I do know that it was a "son of a gun" to get off and on.
