It is currently Fri May 15, 2026 2:04 pm
 Post subject: dana 60 or 8 3/4
PostPosted: Sat Jan 20, 2007 6:47 pm
I'm looking at putting a brand new rear end in my valiant. I figure these are the two that are easiest to get parts for. any suggestions? I figure the 8 3/4 might be easier to get brakes for as well. will also be switching to big bolt pattern.
64' Valiant Signet 5.9, 64' Dart 170 moredoor 3.7, 67' A100 3.7, 00' Dakota SLT 4.7
PostPosted: Sat Jan 20, 2007 6:57 pm
8 3/4 or a F@rd 9 inch.
Don't waste your time and money on a Dana 60
PostPosted: Sun Jan 21, 2007 11:39 am
thanks doc.
 Post subject: FORD 9 "
PostPosted: Mon Jan 22, 2007 5:39 am
I actually know a guy who is selling a modified ford 9" rear all the work to the rear has been done (relocating the spring mounts and such) i think it still needs axles tho. if you want i will give him a call and find out price and stuff.
PostPosted: Tue Jan 23, 2007 4:25 pm
SSRN National Champion
A 8 inch Ford will go in nice and is strong enuff for a Slant just not many gear combinations for it Thanks Ron Parker :D
Bagels On Juice Im On Boost
PostPosted: Wed Jan 24, 2007 4:48 am
Don't really know how many different ratios are available, but I recently got a 4.10 pumpkin, at a swap meet, and a drum to drum rear from a JY. Was much cheaper then an "A" body 8 3/4, and doesn't require the driveshat be shortened.
PostPosted: Wed Jan 24, 2007 5:43 am
The Ford 8" actually has more gear combos available new than an 8 3/4" Mopar.
8" has 2.79, 3.00, 3.25, 3.40, 3.55, 3.80, 4.10, 4.30, and so on...
