It is currently Sat Nov 21, 2026 6:17 am
PostPosted: Mon Jan 22, 2007 2:09 pm
Greetings, I understand some people have had idle, or cold idle issues with the Carter 2 bbl due to two little holes drilled in the throttle plate. I believe this is only on the Carter bbd for 318's. Is this an issue I need to consider when looking for a 2 bbl for a Super Six set up? Thanks
Bill 272727
1972 340 Demon, One family owner
1973 225 Swinger, Second owner, 38,500mi
PostPosted: Mon Jan 22, 2007 7:40 pm
I had a 318 bbd on my dart with the two holes and it really didnt like the cold but my biggest concern was that it wouldnt idle below 1000 rpm,I swapped it out for a super six bbd and it runs and idles much better now and seems a little bit better now that the weather has turned cold during startup in the morning.
HyperValiant
1960 Hyper-Pac Valiant(rolling test-bed)
1963 Valiant V2OO(Son's summer project,- he just turned 15 :-) )
1972 Valiant 4dr(Daughter Kelly's repair in progress)
1974 Valiant (v8) daughter Kelly's work in progress
 Post subject: Can fill...
PostPosted: Mon Jan 22, 2007 9:00 pm
I have seen a few methods that have been used to close that hole for various purposes, just so long as the "repair" doesn't become dislodged and sucked into an intake valve/chamber you should be OK. My current favorite is using a mig welder and making a quick tack to seal it shut (not long enough to build up heat and warp the shaft). I have seen some other methods that are 'not my favorite' on other carbs like JB Weld, solder, drilling and using a small bolt or pop rivet.
good luck on your hunt, and make sure not to overlook the 318 carbs as a cheap source of possible replacement parts for the super six carb if the price is right, and you don't want to do the fill job...
PostPosted: Mon Jan 22, 2007 10:35 pm
I have never had a problem with a 318 carb,with the holes.Old wives tale.The early 318 carb is actually my favorite for the Super Six set-up.
PostPosted: Tue Jan 23, 2007 3:33 am
I also used 318 BBD's for years with no problems. They may need just a little more patience tuning them.
PostPosted: Tue Jan 23, 2007 10:45 am
"Old wive's tale" it is not. Depending on the particular carburetor and its calibration, those holes will often prevent the engine from idling below around 1000 rpm unless you do something ridiculous like retard the base timing to 10° ATDC. You can back the idle speed screw out so far it drops onto the driveway, and still enough air flows through the holes to keep the engine speed higher than you want it. That's not "old wive's tale", that's reality.
PostPosted: Tue Jan 23, 2007 6:08 pm
Not all 318 BBd's have the Holes there - Some of them are incredibly close to the super six carb Except for 3 things:
1 ..089 Jets instead of .086's
2. Thinner Metering rods
3. Larger venturi
I am specificaly speaking of the later BBd's Say 76-and newer.
There are 2 types Dont forget.
I believe the older ones have the Holes in the throttle blades.
PostPosted: Tue Jan 23, 2007 8:50 pm
My bbd was a later high top/tin top carb and it had the holes and reacted just as Dan desribed.
HyperValiant
PostPosted: Wed Jan 24, 2007 8:28 am
hmmmm! I have one I pulled off a 73 truck.
I guess I will go look. :idea:
PostPosted: Sat Feb 03, 2007 9:51 am
I looked! One throttle plate has a nip taken out of it on the edge. No holes. It is located near where one on the idle screws come in. I cleaned this carb up and am waiting for warmer weather to bolt it on and try.
How can I post a pic here?
PostPosted: Sat Feb 03, 2007 7:21 pm
I just put a later model 318 BBD on my /6 and cant get the idle down. however performance got a huge kick in the a$$!!! I'm really not in this car for fuel economy but drivabilty is a factor and a high idle will bug me.
64' Valiant Signet 5.9, 64' Dart 170 moredoor 3.7, 67' A100 3.7, 00' Dakota SLT 4.7
PostPosted: Sun Feb 04, 2007 7:40 am
I use a 66-69 BBD for a 318...no hole,,,no emmisions and no idle issues. It came from NAPA cost $120 and ran like a champ right out of the box.
Users browsing this forum: No registered users and 17 guests
