It is currently Sun Nov 22, 2026 12:13 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 5 posts ]
PostPosted: Wed Feb 06, 2002 12:01 pm
I am going nuts trying to find this thing. I have a 68 dart. I cant find the regulator by reaching under the dash, so i tried to take the dash out. But, I cant get the speedo cable unscrewed from the speedo, and the gauges won't come out. Any help would be great.
Byron
byronpenc@hotmail.com
PostPosted: Wed Feb 06, 2002 1:33 pm
: I am going nuts trying to find this thing. I
: have a 68 dart. I cant find the regulator by
: reaching under the dash, so i tried to take
: the dash out. But, I cant get the speedo
: cable unscrewed from the speedo, and the
: gauges won't come out. Any help would be
: great.
: Byron
The cable doesn't unscrew, you just squeeze the cable end going into the speedo back and a little clip (looks like a fish hook) will let loose and allow you to pull the cable out.
PostPosted: Thu Feb 07, 2002 5:21 am
: great.
: Byron
FYI, I have seen some Darts with the same instrument cluster as the 67-69 Barracuda's. That is, Two large round pods, one for the speedo and one for the fuel/amp/temp/oil. And, a smaller one inbetween for the tach. If you have this cluster the instrument voltage regulator is integrated into the gas gauge, that is, there is not a separate IVR on the panel.
Dave Clement
Hot-Rod 6
dave.clement@motorola.com
PostPosted: Thu Feb 07, 2002 9:49 am
: The cable doesn't unscrew, you just squeeze the
: cable end going into the speedo back and a
: little clip (looks like a fish hook) will
: let loose and allow you to pull the cable
: out.
: Lou
So, i just squeeze with pliers and pull? That sounds too easy. I will give it a shot, thanks fo the help.
Byron
PostPosted: Thu Feb 07, 2002 3:04 pm
: So, i just squeeze with pliers and pull? That
: sounds too easy. I will give it a shot,
: thanks fo the help.
: Byron
You don't need pliers, just squeeze with your fingers.
Chuck
webmaster@omnipages.com
