It is currently Tue May 19, 2026 7:25 am
PostPosted: Fri Jan 26, 2007 12:33 pm
I put a drum on backwards with 3 backwards lug nuts and the driver's side popped out easily.
The passenger side won't budge.
I got a shop light and magnifying glass and looked for some kind of retainer inside the housing, but can see none.
Any tricks to getting this one out?
PostPosted: Fri Jan 26, 2007 1:12 pm
No trix no clips.
PostPosted: Fri Jan 26, 2007 1:25 pm
The stethoscope said the bearing on this side is noisy
Is being difficult to remove a symptom of a bad bearing?
There's no bigger tool that I can rent or buy?
Is this where other people just give up?
Should I get a larger person or a master of Bruce Lee's one-inch punch?
PostPosted: Fri Jan 26, 2007 1:31 pm
I had a junk axle i was trying to pull the axles out of to get all the brakes off and i tryed everything to try to get them loose and no luck i just gave up
PostPosted: Fri Jan 26, 2007 1:45 pm
You should be able to borrow a slide hammer axle puller from Auto Zone. Those usually do the trick.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Fri Jan 26, 2007 2:10 pm
Car Model: '23 T-bucket
Find a log chain big enough that you can bolt the end link to one of your wheel studs. Grab the free end, and "crack" it, like cracking a whip. The chain wil act like a slide hammer, and after a few cracks, the axle should slide out at your feet.
Roger
PostPosted: Fri Jan 26, 2007 2:14 pm
Take the drum off, put a wheel on, and whack it with a big hammer. Always works for me. :shock:
PostPosted: Fri Jan 26, 2007 2:19 pm
Ah ha! I called Schucks and they have such a tool!!
I'm walking over there now and will try this again, in a more fully-assed manner.
PostPosted: Fri Jan 26, 2007 2:21 pm
Whack the rubber tire, or whack the steel wheel?
PostPosted: Fri Jan 26, 2007 2:28 pm
Whack the steel wheel.....whacking the rubber will get you hurt.
~insert cartoon of rebounding 20lb sledge~
This is not an application for alloy rims....but perfect for bent 13" steelies.
May I suggest the strengthening powers of a few good ales?....mebbe with a few strong buddies?
PostPosted: Fri Jan 26, 2007 5:44 pm
Well, the puller was for a front-drive car.
I'll try the 3-lb hammer on a 13" rim.
It won't bend the axle to hit the wheel so far off the centerline of the axle?
PostPosted: Fri Jan 26, 2007 5:57 pm
Well, that sux. Good luck with the hammer and wheel method.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Fri Jan 26, 2007 6:39 pm
Are you sure it's not a 5 bolt retainer :wink: :)
You asked if this was a symptom of a bad bearing. It could be that the race has spun in the housing, in which case you're probably going to be shopping for an entire unit.
Have you pulled the cover yet? You may be able to pry against the cross shaft to add some force.
Don't give up - you'll beat it sooner or later.
O==\=/==O
"A mechanic is Somebody."
- Jim Preston
PostPosted: Fri Jan 26, 2007 7:08 pm
The cover's off.
Pry against the cross shaft?
You can pry there?
The driver's side bearing feels good.
Do I need to replace the inner seal now that I pulled it?
If I can't get the axle out by mid-day tomorrow, I plan to put the axle shaft back in and drive the car this weekend to find a big slide hammer puller with a claw that fits a 5-on-4 bolts pattern.
It's my only car.
PostPosted: Fri Jan 26, 2007 7:31 pm
A wedge is a powerful tool...
Drive a wedge (cold chisel) between the end of the axle shaft and the spider gear cross shaft and that axle will pop-out. (or at least break loose enough to use one of the previously discribed methods for complete removal.
