It is currently Sat Nov 21, 2026 7:02 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 8 posts ]
PostPosted: Fri Feb 08, 2002 5:34 pm
I read the other day about how AMC 258cid inline Sixes went to a spark plug for '79 with an extra-extended set of electrodes. The theory, which
is still stated in various spark plug science/technology literature in relation to such plugs, is that this moves the spark further down into the
combustion chamber, which reduces mixture variance in the immediate vicinity of the electrodes by getting the spark AWAY from the quenchout area (which coincidentally reduces HC emissions). It also has the effect of making the flame front hit the piston fractionally sooner, which is said to have the positive effects of advancing the timing slightly without the detonation problems.
The spark plug that does all this is Champion RN13LYC, Autolite 925 or NGK ZGR5. This is right smack in the middle of the two heat ranges generally used in Slant-6s with early ('60-'74 style) heads. All mechanical aspects of these plugs (seat, hex, thread size and length, etc.) is identical to the standard SL6 plugs.
Now, my one remaining SL6 car is in storage in another country, so I can't readily try these plugs in it yet, but I did carefully put a set in my 2.5 litre LeBaron this afternoon. As some of you may know, the K-car 2.2/2.5 is based heavily on the 225. I confirmed "no piston-to-spark plug interference" by removing all the plugs, disabling the ignition, and installing ONE of the special plugs until the gasket seated, then unscrewing it a few turns, cranking the engine, removing and inspecting the plug. I did this a few times, putting it in further each time, until the plug was all the way in. No problem. Given the huge negative deck height of the SL6, I cannot imagine there being any interference.
So far, so good...cold starting and running seem better and the idle seems smoother, compared to the month-old, perfectly good/clean standard-length plugs I had in there before. I'll be keeping a close eye on mileage; this may be an easy way to pick up a little efficiency and driveability (and maybe shave a few tenths?)
DS
redbear@vrx.net
PostPosted: Sat Feb 09, 2002 12:00 am
I can hear it now "when milling my head,should I check piston to spark clearence"
Good goin Dan. I also have a 2.2 shelby csx, I could try the same, but dont want a electrode in my engine ACK!! keep us updated, this could be good for gas and start up!!!
: I read the other day about how AMC 258cid
: inline Sixes went to a spark plug for '79
: with an extra-extended set of electrodes.
: The theory, which
: is still stated in various spark plug
: science/technology literature in relation to
: such plugs, is that this moves the spark
: further down into the
: combustion chamber, which reduces mixture
: variance in the immediate vicinity of the
: electrodes by getting the spark AWAY from
: the quenchout area (which coincidentally
: reduces HC emissions). It also has the
: effect of making the flame front hit the
: piston fractionally sooner, which is said to
: have the positive effects of advancing the
: timing slightly without the detonation
: problems.
: The spark plug that does all this is Champion
: RN13LYC, Autolite 925 or NGK ZGR5. This is
: right smack in the middle of the two heat
: ranges generally used in Slant-6s with early
: ('60-'74 style) heads. All mechanical
: aspects of these plugs (seat, hex, thread
: size and length, etc.) is identical to the
: standard SL6 plugs.
: Now, my one remaining SL6 car is in storage in
: another country, so I can't readily try
: these plugs in it yet, but I did carefully
: put a set in my 2.5 litre LeBaron this
: afternoon. As some of you may know, the
: K-car 2.2/2.5 is based heavily on the 225. I
: confirmed "no piston-to-spark plug
: interference" by removing all the
: plugs, disabling the ignition, and
: installing ONE of the special plugs until
: the gasket seated, then unscrewing it a few
: turns, cranking the engine, removing and
: inspecting the plug. I did this a few times,
: putting it in further each time, until the
: plug was all the way in. No problem. Given
: the huge negative deck height of the SL6, I
: cannot imagine there being any interference.
: So far, so good...cold starting and running
: seem better and the idle seems smoother,
: compared to the month-old, perfectly
: good/clean standard-length plugs I had in
: there before. I'll be keeping a close eye on
: mileage; this may be an easy way to pick up
: a little efficiency and driveability (and
: maybe shave a few tenths?)
: DS
kewda225ci@aol.com
PostPosted: Sat Feb 09, 2002 1:00 am
: The theory, which
: problems.
: DS
Are these plugs for the later small plug heads, or the early heads with the spark plug tubes?
Eric W
My Big B
ecwfury@webtv.net
PostPosted: Sat Feb 09, 2002 8:15 am
: Are these plugs for the later small plug heads,
: or the early heads with the spark plug
: tubes?
Eric-
This info was in my original post. They're for early-style heads. There may be an extended-electrode plug that would fit the later-style head; I have not looked.
-DS
redbear@vrx.net
PostPosted: Sat Feb 09, 2002 11:34 am
: Eric-
: This info was in my original post. They're for
: early-style heads. There may be an
: extended-electrode plug that would fit the
: later-style head; I have not looked.
: -DS
Oh. Well, I have a '73 engine in my Satellite, so that will work for me! I always used Autolite 56's, so I dont know much about spark plug numbers. Are these plugs you mentioned a good heat range for a 50-50 mix of in town/freeway driving?
My Big B
ecwfury@webtv.net
PostPosted: Sat Feb 09, 2002 7:20 pm
: Oh. Well, I have a '73 engine in my Satellite,
: so that will work for me! I always used
: Autolite 56's, so I dont know much about
: spark plug numbers. Are these plugs you
: mentioned a good heat range for a 50-50 mix
: of in town/freeway driving?
I like Autolites, myself, too. They are no longer possible to obtain in Canada (that I've found in the Toronto area) so I had to settle for Champions.
The Autolite 56 is a good plug. The harder-to-find 4256 is better (the 42xx series has a necked-down centre electrode, which provides more mixture access to the spark) and the special-order MP4256DPE (which is used on some Harley-Davidson motorcycles) has the necked-down centre electrode AND a cut-back side electrode, which still further improves mixture access to the spark. These are all variants of the basic #56 plug, they all have the same heat range and mechanical characteristics, just with different electrodes.
The long-electrode plug (Autolite 925) has a heat range that is between number 55 and number 56, so should suit just fine. Because I can't get Autolites, I can't run a comparison between the MP4256DPE and the 925, but after 150 miles today, my 2.5 is running fine on the long-electrode plugs and seems to have a bit more pulling power. I'm keeping an eye on mileage.
Most of the "gimmick" plugs ("Splitfire" etc.) are a waste of money, and I've had poor results with Bosch Platinums. Plugs of essentially standard construction from Autolite, NGK, Champion or AC are the ones I stick with, but as you can see, within that constraint there are LOTS of different variants to try out!
DS
redbear@vrx.net
PostPosted: Sun Feb 10, 2002 12:07 am
: I like Autolites, myself, too. They are no
: longer possible to obtain in Canada (that
: I've found in the Toronto area) so I had to
: settle for Champions.
: The Autolite 56 is a good plug. The
: harder-to-find 4256 is better (the 42xx
: series has a necked-down centre electrode,
: which provides more mixture access to the
: spark) and the special-order MP4256DPE
: (which is used on some Harley-Davidson
: motorcycles) has the necked-down centre
: electrode AND a cut-back side electrode,
: which still further improves mixture access
: to the spark. These are all variants of the
: basic #56 plug, they all have the same heat
: range and mechanical characteristics, just
: with different electrodes.
: The long-electrode plug (Autolite 925) has a
: heat range that is between number 55 and
: number 56, so should suit just fine. Because
: I can't get Autolites, I can't run a
: comparison between the MP4256DPE and the
: 925, but after 150 miles today, my 2.5 is
: running fine on the long-electrode plugs and
: seems to have a bit more pulling power. I'm
: keeping an eye on mileage.
: Most of the "gimmick" plugs
: ("Splitfire" etc.) are a waste of
: money, and I've had poor results with Bosch
: Platinums. Plugs of essentially standard
: construction from Autolite, NGK, Champion or
: AC are the ones I stick with, but as you can
: see, within that constraint there are LOTS
: of different variants to try out!
: DS
I agree with you on the "gimmick" plugs Dan. I got some platnum tip plugs (Autolite's) and could honestly tell no difference. I just thought that maybe they would last longer. I am going to get an Accel Super Stock coil tomorrow, so I think I will get some of the plugs you recommend while I'm at it. As always, thanks for the advice Dan!
Eric W
My Big B
ecwfury@webtv.net
PostPosted: Mon Feb 11, 2002 6:21 am
: I agree with you on the "gimmick"
: plugs Dan. I got some platnum tip plugs
: (Autolite's) and could honestly tell no
: difference. I just thought that maybe they
: would last longer. I am going to get an
: Accel Super Stock coil tomorrow, so I think
: I will get some of the plugs you recommend
: while I'm at it. As always, thanks for the
: advice Dan!
: Eric W
I have been using Autolite Platinums since they first appeared back in the late 80's. They absolutly do not make any differnce in performance or milage compared to a new conventional plug but they do last for 60,000 or more miles. I typically leave them in for 60,000 miles and they have maybe 0.001" to 0.002" of gap growth.
Since you can get these on sale for $1.50 each the small addtional price increase is worth the convience of not having to change plugs every year in 4 cars.
Hot-Rod 6
dave.clement@motorola.com
