It is currently Fri Nov 20, 2026 12:04 pm
 Post subject: Oil pump gear removal
PostPosted: Sat Jan 27, 2007 5:31 pm
Where can I get one of these pullers to remove a gear or can it be done with a simple 12 ton press?
PostPosted: Sat Jan 27, 2007 5:41 pm
When reinstalling the gear I read to heat the gear and freeze the shaft. How hot to heat the gear? I don't want to get it to hot with the torch.
PostPosted: Sat Jan 27, 2007 7:04 pm
If your shaft / gear has a keyway, you must use a puller.
I use a toster oven to heat my gears, 400 degrees is about right.
Users browsing this forum: Google [Bot] and 10 guests
